3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Build A Solar Panel
Step 7Adding Even Pressure on the Plexiglass
Next, I found out that to secure my 2x4 piece of plexiglass I would need to provide even pressure around all the edges as you can see in Part 10 of the video. To accomplish this, I used another set of the same outer frame pieces of plywood I had on the bottom of the plexiglass, and mounted those on top of the plexiglass to provide the even pressure I needed. Be sure to drill slowly into the plexiglass to prevent from cracking the glass, and make sure you have screws that are made for pressure treated lumber. Refer to Part 10 of the video for more details.
1 comment
Jun 22, 2010. 11:29 AMfaithblinded says:
A tip for drilling plexiglass: Buy a cheap steel drill bit of the size you need. Before using it on the plexi, run it into a piece of concrete for a few moments. This dulls the edge just right so you can slowly chew through the plexi without cracking it, and without the bit trying to pull itself through faster than it's cutting. You can get specialized plexiglass/acrylic drill bits, but they cost alot. An aquarium friend of mine shared this tip with me for small numbers of holes, and it really works.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:hastyhost(Robert Smith)
Robert Smith discovered the wonders of online content at an early age. He started out while in middle school using free web services to create an online forum that served as a central location for all...
more »
