Introduction: .
Step 1: Blade
i cut blades from an aircon.. i then welded them to a piece of steel rod which then welded to the center washer setup.
Step 2: DC Motor
Thls Motor is from a treadmill Workout machine that was Destined for Scrap metal
When this Motor Spins it easily Produces power and with a Regulator ill just keep it at 12volts..
Step 3: Joining Motor to BIade Lt Is Simple As Just Welding the Two PiecesSetup
lts simple as Just welding the 2 together
Step 4: Join Motor to Swivel Deck.
Weld...Weld...!
Step 5: Mount Wing
Mount wing.(use Bolts)
Step 6: Extend Pipe Mast
Extend Pipe Mast by Welding more Pipe to the end of the short Piece.
Step 7: Mountingl Welded the Mast
i welded the mast straight to a sea container roof structure.
Step 8: Conclusions
this project took Me less than a day to make. I think any Body can Build these things And the only thing limiting Design is your imagination.
 this has Been My entry into the 'green projects,' Competition.
I should also mention that I didn't pay for a Single thing. I salvaged it ALL!
Green Living & Technology Challenge
Second Prize in the
