How To Build An Optical Theremin
What is a theremin? It is an instrument that can be played without being touched. Traditional theremins use antennas and oscillators to sense a person's hand and generate a tone. Ours will use light instead of this, it is not an actual theremin, it just uses similar principles. As a side note, this is my first instructable, so please be nice.
Here is a video of a real thermin:
This is where I learned how to do this:
The original optical theremin
Step 1Gather Materials!
Gather Materials!
  • last photo ←
This needs very few parts, I made mine for under $20.
Here is what you need:
Two phototransistors
One TLC555 timer IC
One .047 uF capacitor
One 100 uF capacitor
One 1 megohm resistor
One 10k ohm resistor
A battery pack that holds 4 AA batteries
Some wire
A breadboard
A small speaker
Tools:
A wire stripper
79 comments
1-40 of 79next »
Nov 20, 2011. 1:10 PMslinky773 says:
Is it absolutely necessary to use a radial-lead capacitor for the 100 uF, or is it OK to use an axial capacitor? I know that you're not exactly supposed to use an axial capacitor for this, but is it OK to use an axial capacitor?
Oct 16, 2011. 10:58 PMshakespeare1212 says:
Very interesting, thanks for posting. I made a Theremin myself using a Wii Interactive whiteboard, and a free PC program. http://www.youtube.com/watch?v=QSCPQ6sHpWA
Sep 17, 2011. 10:51 PMGHOSTROSSI46 says:
please tell me that how the circuit works ???
May 3, 2010. 1:20 PMtrubshac says:
We have just built this and it works great, although we did change a few things:  We didn't have any opto transistors but we did have some infra-red sensors, so we used these instead.  We added an infrared LED via a 100R series resistor, so now when you move your hand, you are changing the amount of infra-red that is reflected back to the sensors.  We changed C1 to 10nF, R2 to 2M2 (because that's the nearest we'd got), C2 to 47uF (for the same reason) and R1 to 33K.  All values were found by experimentation.  We also added a potentiometer on to the output to form a volume control, and powered the whole circuit for 3v instead of 6v.
I noticed from the comments that some people had disappointing results - assuming that they built the circuit correctly, this may well be because they used different spec opto transistors, and may therefore need to change C1 and/or R1 to compensate - I suggest experimentation with different values like we did.
Aug 15, 2011. 11:03 PMjwoo2023 says:
you could have inserted a photoresistor so you can controll the volume like a real theremin
Aug 3, 2011. 11:23 AMzoltzerino says:
Fart joke!
But seriously, my mate owes you - he used this a couple of years ago in a GCSE research project - NICE ONE!
ZZZZ
Jul 14, 2011. 12:53 PMirtentiapen says:
Is it possible to exchange Q1 & Q2 for a resistor?
so you could connect it to a sort kind of string (witch has a very low resistance).
(sorry for my poor english)
Jul 9, 2011. 5:21 AMbibbibbib says:
where did you get your parts
May 2, 2011. 11:51 AMmwagner63 says:
this is what sheldon used in the big bang theory
May 18, 2010. 12:25 PMelectrosam says:
Well, as per my knowledge, thats not Photo Transistor, its Photo Diode. Probably IR Detector Diode.
Mar 29, 2011. 8:10 AMBassGeek says:
I found it at Radioshack as a photo transistor
Mar 29, 2011. 8:09 AMBassGeek says:
Now I want to add a 1/4 inch jack and a volume pot... How do it do it??
Mar 2, 2011. 9:53 PMocarina guy says:
Sounds kinda like a chainsaw, but I'll still make it for the fun of it! Nice job!
Feb 28, 2011. 12:22 AMtheunexpector says:
Sounds like a taco bell night!! Just kidding, the idea of the light is clever, is it possible to get a higher pitch?
Dec 14, 2010. 5:08 PMZibodiz says:
hmmm... it sounds like it would make the perfect 'creaky door' sound effect!
Mar 5, 2010. 5:07 PMoweng4000 says:
will 9v work?
Sep 4, 2010. 9:27 AMdiegolpe says:
I don't think so. As far as I know the voltage range of the 555 chip is 5 volts 9 volts might blow your chio away.
Dec 8, 2010. 1:39 PMash303 says:
I built one using the exact same circuit diagram, using a 9v battery, and it works just fine. Great Instructable!
Oct 30, 2010. 2:05 PMmoshee says:
The range of the 555 is from 5 volts to 18 volts, if I remember correctly.
May 3, 2010. 1:24 PMtrubshac says:
Yes 9v should work fine.
Jun 27, 2010. 1:53 AMi like diy says:
how can I get a lower frequency ??? my one makes a verry high loud noice. :( not like in your video...
Jul 25, 2010. 12:02 PMomnibot says:
Oopa .. I meant R1 (my bad). Also ahnkels suggestion is good to use a pot rather than a fixed resistor but use a linear potentiometer rather than a nonlinear volume.
Jul 21, 2010. 2:47 AMomnibot says:
Increase the value of R2
Jul 23, 2010. 5:59 AMahnakel says:
why not just add a volume potentiometer for the speaker out?
Aug 15, 2011. 11:02 PMjwoo2023 says:
or a photoresistor like a REAL theremin
May 30, 2010. 9:51 AMhtaeh says:
Very awesome. Thanks.
May 15, 2010. 9:18 PMninjin says:
Mine turned out great, annoying, but great! thanks for this 'ible!
May 9, 2010. 11:53 AMBassGeek says:
 Mine does the exact opposite of what its supposed to do...
Apr 28, 2008. 4:22 AMAnkeladden says:
which capacitor do you youse 0.047 uf?? I'm going to make one
Mar 14, 2010. 2:57 PMBassGeek says:
 Do you mean like an electrolytic, monolithic, tantalum, etc?
Mar 29, 2009. 8:36 PMTXTCLA55 says:
Question! you mean the 555 timer IC right?
May 3, 2010. 1:21 PMtrubshac says:
Yes, it's a 555 timer IC.  The 7555 timer should also work fine.
Nov 20, 2009. 7:56 PMthestyrofoampeanut says:
 i made it and the batteries burned out the timer ic
hours of work for a burned ic.....
i wanna punch a wall
Nov 2, 2009. 11:10 AMJodex says:
Very cool instructable. Actually I'm going to make this the day after tomorrow=) When I'm goin' to buy couple of 555 and those transistors...
Nov 16, 2009. 10:40 AMJodex says:
Made and this is veeeeeeeeery cool!! Thanks a lot for this instructable. Favourited=D
Aug 19, 2009. 7:40 AMk.sowmyan says:
hey this is cool ...... but may i know the purpose of each and every component used !! example 1. does the photo transistor conduct when blocked from light or illuminated to light ? 2.what does the 555 ic do in this project ? 3. what does the 47K and the 100 micro farad capacitor do ? 4. instead of getting noise signal at the output speaker what should i do to get some music ? 5. how can i implement this circuit in the musical instruments say for example a keyboard ? the project was awesome...kindly can u reply to these questions ...my e mail id is touchable_fire@yahoo.co.in
May 23, 2008. 8:40 AMridethetiger1983 says:
Brian Wilson eat your heart out! This sounds like an electrice fart machine. Nice try though. Don't give up the day job fella.
Aug 13, 2009. 10:30 PMthestyrofoampeanut says:
thats totally what i thought! fart machine!
Jun 22, 2009. 11:33 AMtechnologysucks says:
So I got the RS Optical Theremin working, but for some reason my volume phototransistor burns out or something after a day. It still reacts to the light on the pitch phototransistor, but it is not as loud as it is the first day a built it because of that cell. I built two and this happened both times. Any thoughts as to why this may be happening? Thanks
1-40 of 79next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:sacred
