How to Build ThunderBumm & SpittleFumm Out of Legos
Published
Introduction: How to Build ThunderBumm & SpittleFumm Out of Legos
About: Hello, we are ThunderBumm and SpittleFumm! We love doing art and animations, all sorts of that stuff. We also have a YouTube channel, which is the same name as our instructables.
Build Our YouTube Mascot, ThunderBumm & SpittleFumm, out of legos!
Step 1: Let's Start With ThunderBumm.
This Guy took me an hour to find the correct pieces to make him.
Step 2: Let's Start With the Feet.
1. Gather the pieces shown in the picture.
2.Put Connector piece and 1 stud green piece together.
3. Now add the last connector, and you have finished the legs!
Step 3: Now... the Body.
1. Gather the parts shown in the picture.
2. Connect these three connector pieces. You now got the first part of the body.
3. Add this hook piece shown in the picture, because this will be the tail.
4. Add a flat, no stud piece on the bottom, and a middle stud piece on the top.
5. Add cylinder piece and stud.
6. Put a 2 by 1 piece on the bottom, at the top (The chest kind of area). You are now finished with the body.
Step 4: Let's Connect the Feet and Body.
Step 5: Arms... Way to Easy.
The arms to ThunderBumm are different than SpittleFumm.
2. Put the white hook piece under the 1 by 2 green piece.
3. Put the gray hook piece under the second 1 by 2 green piece.
You are now finished with the arms.
Step 6: Let's Now Connect Them to the Body.
Step 7: Add 2 More Pieces to the Body.
Step 8: Last... the Head.
2. Add 2 by 3 flat piece to a 2 by 3 brick piece.
3. Add the L piece on the bottom.
4. Add the 2 by 1 flat piece on the bottom, too.
5. Add a up and down hook piece in the top middle.
6. Then add the studs to be his spikes.
You are now finished with the head, including all of ThunderBumm too.
Step 9: You Are Now Finished With ThunderBumm.
Step 10: Now's Time to Build SpittleFumm.
You can build SpittleFumm with the same, just I didn't have enough pieces to make SpittleFumm almost exactly like ThunderBumm, so I guess this is another way to build both of them.
Step 11: The Legs Are Always First.
You can tell that there is one two pieces that are different then ThunderBumm's legs.
2. Connect the hook pieces to the 1 by 1 brick.
3. Then add the connector pieces.
You have now finished the legs.
Step 12: His Body.
You can also tell in SpittleFumm's body that the pieces are different colors.
1. Gather the pieces in the picture.
2. Add the two connector pieces, then add the tail part, including a connector part above.
3. Add the middle stud part on the top, and the vent part on the bottom. You are now finished with the body.
Step 13: Connect the Legs to the Body.
Step 14: Another Easy Part.
It is probably the easiest parts to find out of all your legos.
1. Gather the Pieces shown in the picture.
2. Put the vent part on the side by side hook for both arms. You are now finished with the arms.
Step 15: Connect the Arms to the Body.
Step 16: Add 2 More Pieces to the Body.
Step 17: Now. Off With the Head.
This is probably the only body part with the same parts as the other head, just color difference.
2. Put the 2 by 3 flat piece under the 2 by 3 brick piece.
3. Add the L shaped Lego on the bottom.
4. Add the 1 by 2 piece in the missing space.
5. Add the up and down hook in the last little bit of missing space.
6. Then add the studs for SpittleFumm's spikes. Your are now finished with the head, and the whole thing!
Step 18: Hooray! You Built ThunderBumm & SpittleFumm!
You finished the Instructable!
Step 19: Please Subscribe to My YouTube Channel!
It is named ThunderBumm & SpittleFumm, but the name is still being loaded, so search ThunderBumm Studios, and you will find it!
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    2 Comments
