3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Build Your Own Pedicab
Step 7My Specifics: Notes On Tongue Design
The area of the pedicab in front of the footrest gets a LOT of force applied to it: it's the end of a lever with your passengers at the other end.
My first designs bent so much that one actually bottomed out when I tried to brake, which would not have made for a very customer-friendly experience or me-friendly tip.
So, to arrive at the final product pictured, I found a couple of books on car trailer design (specifically, volumes 1 & 2 of M. M. Smith's "Trailers: How To Design & Build"). You can also check out what trailer hitches look like or just reason through some of the key points:
-load is spread between multiple attachment points to trailer
-tubing that bears the full weight of the pedicab is reinforced
-multiple grade 5 bolts secure each part of the tongue
Experiment with design on this part, and let me know what you come up with!
2 comments
Sep 15, 2008. 7:27 AMirwoman says:
The leaders of the industry must all agree that this is so unsafe! Just check them out. All schematics state structured framing is TIG weld. Placement of seat a difinite danger. Author even admits bottoming out on first try. Nuts & Bolts??? A bolt will snap in a high force collision. This is an accident waiting to happen. Cannot believe it was licensed in Austin. Competion is welcomed in the field of building pedicabs but anyone doing so really needs to do their homework and check out industry standards.
Aug 18, 2011. 4:52 AMcwilliams34 says:
If bolts are so dangerous why are they used to attach many things (including the engine) to an Airplane or a Car? those DANGEROUS bolts hold your seat in the case of a crash in car, just look under your seat....Granted welding is important but it can also weaken a structure. All in all this guy took his time to design and work out a method that functions....what have you designed and built lately? I have been desiging and building things that fly for years. Planes, kites, parafoils, I can;t tell you how many people HELPED me. You need to consider the concept of lifting people up and not tear down. I think you have information you could share and help guide people like this and educate them on HOW to build safer.
Nov 23, 2009. 2:13 AMdigitalmouse says:
"...leaders of the industry must all agree..."   erm hello?  What leaders of industry are there in pedicab construction?  I bet you can't name three.  I'm *in* the industry and I can't name three 'leaders'.  We all do the best we can with what we have to provide a safe and comfortable journey.  One of the best pedicabs out there is a model of an Indian pedicab, which is a cycle bolted or welded to a cab frame.  I've ridden many of these, and they don't conform to any 'standard' I know.  They are just built strong.
Of course a bolt may snap in a high force collision.  Since a pedicab does not go very fast to begin with,  it won't be because the cab is unsafe, but because the car/truck crashing into them is at fault.  People have the mistaken impression that pedicabs are meant to be as safe as cars.  Bzzt!  Wrong answer!  But thanks for playing.
Pedicabs are meant to be light, enviromentally friendly, comfy alternatives to motorized taxis or walking.   Nothing more, nothing less, aside from making sure the cab can withstand the day-to-day usage of it's driver and riders.  *NO* pedicab can withstand a 'high force' collision.
That's like saying bicycle helmets are designed to protect you from death.  Below 20kph you'll likely fall on your hands and knees.  Above 20 kph (like being hit by a car), no cycle helmet in the world is designed to save you.  It comes down to skill of the rider or sheer luck of survivability.
"...this is an accident waiting to happen..."  if so, then keep the cars off the streets in town!  :-)
Oct 22, 2009. 10:43 PMLokisgodhi says:
"A bolt will snap in a high force collision "
That's garbage. It's all the matter of choosing the proper grade hardware. Obviously you've never heard of the  SAE J429 standard, grade 0 to 8, for bolts.
Bolts hold wheels on to automotive axles for thousands of miles bouncing over dirt roads without shearing off. They hold leaf springs on to frames while resisting hundreds of ft-lbs of shearing force during hard acceleration or deceleration. They hold girders together with millions of tons pressing down on them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
66
Author:liseman
bicycles, gardening, and other important stuff
