Introduction: How to Build a Custom Sized Gate
Picture of How to Build a Custom Sized Gate
If you're in need of a gate, then why not build it yourself. Using this method, you can make a custom sized gate, that is lightweight yet rigid and quite affordable. The measurements will differ depending on what size gate you need, however the principle model remains the same.
I needed a rather large gate - 6 feet high, and 4 feet across. I wanted the gate to provide privacy, and to be sturdy, yet light. Considering 24 square feet is a big surface, I was concerned with stability and decided to go with brackets to stiffen up the frame considerably without adding extra weight. Now, in order to keep the gate lightweight, yet provide privacy, I'm going to be using cedar boards for the frame and cedar pickets for screening. So for the frame I need center support to attach the pickets too.
Step 1: Materials & Tools
So for this build - you're going to need wood, I'm using cedar because it's lightweight and perfect to use outdoors.
Pieces Needed:
  • 2 long side rails (the height of your gate)
  • 4 middle pieces (width of your gate minus the width of the side rails)
  • Set of brackets to secure the frame
  • Nailing strips
  • Cedar pickets
Tools Needed:
  • Drill
  • Staple gun
  • Exterior screws
  • Staples
Step 2: Cutting & Assembling
Picture of Cutting & Assembling
Step 1 - Cutting up the wood
Start with cutting up your wood to size. I started with a big piece of cedar and had to use the circular saw to make the first cut, and then I completed the cuts on the table saw. I cut up the brackets on the miter saw.
Once I had all the pieces for the frame cut up, I laid them out on the grass to see how everything fit.
Step 2 - Assembling the Frame
Now let's move on to assembling. To put together the frame, pre-drill first and secure with screws. Also screw in the brackets and attach the nailing strips.
Step 3- Attach the pickets
Pickets are great to use for screening because they're already 4 feet across, plus they're cheap and lightweight. Line up the pickets and staple them into the nailing strips using a staple gun.
Step 3: Install the Gate
Picture of Install the Gate
Step 4 - Hang the gate
To attach the gate, screw in hinges and hang the gate either from a fence post or other structure.
Step 5 - Put in a closing system
It can be practical to put in a closing / latching system. I decided to go simple. I cut out a hook on the bandsaw which I attached to the wall with screws. I drilled a hole into the gate and created a loop with a rope that falls into the hook.
Step 4: ​Conclusion - Watch the Video
To get a better perspective, make sure you check out the video that goes over all the steps. This project is easy to customize to make it fit your specific requirements.
SusanI8 (author)2016-04-24
How is this holding up for you, Linn? I had two concerns - the hinges look like they're small indoor brass hinges, and I'd think you'd need something bigger and coated or treated to hold up to weather.
Second - is the bracing strong enough to maintain bottom clearance? Without a full cross brace like redmarkonthewall shows below I think the latch side lower corner is going to start drooping and scraping.
3366carlos (author)2015-08-16
nice, a locking system may be a good idea, you don't Fido to get out.
Jobar007 (author)2015-06-23
Your hinges look awful small. I admit that I don't know much about fencing, but they just don't look like they are large enough to handle that large of a gate.
Your gate looks great. I really like the cedar on cedar.
redmarkonthewall (author)2015-06-23
I found the easiest and best way to prevent a large or any size gate from sagging is the way I made my 4' wide by 6' tall gate. By running an angled board from the top outside to the bottom hinge side you help distribute the weight of the gate thereby preventing sagging. This design was super simple and easy to build in any size. Just thought I'd put that out there.
About This Instructable
2,036views
46favorites
Bio: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check ... More »
More by darbinorvar:Mini Workbench W/ Woodworking Vise & ClampsBent PVC LED Desk Light8 Easy DIY Leather Christmas Gifts
Add instructable to:
