Introduction: How to "Carbon Fiber" Anything
Picture of How to "Carbon Fiber" Anything
We all know Carbon Fiber is friggin' AWESOME! So, why don't we make some of our things have or look like they have Carbon Fiber on it! My dad recently bought some Carbon Fiber vinyl and I thought up this amazingness. I've Carbon Fibered my phone backplate and I'll be demonstrating on how to Carbon Fiber something on a little LED keychain light. The Carbon Fiber Vinyl is very realistic (if you buy the right kind) and is very cheap compared to (let's say) a phone case/cover made from real Carbon Fiber. Read on to discover how to do this and some more mad pictures.
Step 1: Materials
Picture of Materials
O.K. so this is whatcha' need:
-Object to be Carbon Fibered
-Carbon Fiber vinyl
-Paper towels
-Cleaning solution
-X-Acto Knife
*IF APPLICABLE TO YOUR PROJECT*
-Hair Dryer
-Dismantling tools
Step 2: Disassemble Your Item
Picture of Disassemble Your Item
If you have an item that can be disassembled to make the Carbon Fibering easier, do it. Take pictures of the way it is put together for reference when you later reassemble it.
Step 3: Applying & Cut Fitting the Carbon Fiber (Plus More Methods)
Picture of Applying & Cut Fitting the Carbon Fiber (Plus More Methods)
Since my object is flat, it is very easy to apply the Carbon Fiber vinyl. Place it on the Carbon Fiber and cut around your item, being sure to leave a little bit of vinyl on the edges so it can be trimmed exactly. After cutting the shape, clean your object and apply the vinyl to it.Then, cut off excess vinyl using your object as a template. If you are doing something that has round parts like a car hood, or phone case, use a hairdryer to make the vinyl more flexible so that it conforms to the rounded edges. If you are wrapping something else that you don't want to take apart you can make a template of it using paper and further trim it until it is exact and then apply it. If you have holes that need to cut out of the vinyl (ex. the button hole in my project) use the edge of the hole to cut out the covering piece.
Step 4: Touch-Ups
Picture of Touch-Ups
Use a permanent marker to touch-up any colors that are showing from your original object. Edges are usually and usually need to be touched-up. Look at the pictures for help.
Step 5: Reassembly
Picture of Reassembly
Reassemble your object by reversing the steps you took to disassemble it.
Step 6: Results
Picture of Results
My results turned out very nice. If you want to even think about attempting this, remember this: DO NOT RUSH!!! The time required for this project varies because of the different shapes, objects, and items that can be wrapped/Carbon Fibered. If you need help, just ask for it in the comments and I'll respond A.S.A.P.
Thanks!
pucksurfer (author)2014-06-06
And also where did you buy you vinyl from?
MarkYu (author)pucksurfer2014-06-08
eBay. There is also some on Amazon with free shipping, but I don't know how well they look or how well they apply onto something.
Yonatan24 (author)MarkYu2015-09-25
Isn't that kind of carbon called "Kevlar"?
UK Ninja96 (author)Yonatan242016-02-26
Kevlar is a diffrent material that can be used like carbon fiber or as a fabric (like bullet proof vests) this is just carbon fiber vinyl wrap. kevlar is more of a yellow/gold colour :)
ドラゴンマ (author)2015-11-03
I find the title of this to be a bit misleading. I think a more appropriate title would be "How to Apply Decorative Vinyl Sheet to Anything", or something similar. Then you can say in the intro that you are using carbon fiber printed vinyl. That way you'd clear up any confusion for people searching on how to apply real carbon fiber.
Just a suggestion. The actual application of the vinyl looks really clean! Dealing with adhesive sheets like this can be tricky.
私は第二のこと
fozzy13 (author)2014-06-06
Just so everything is clear: This is not carbon fiber, only vinyl sheet with a carbon fiber pattern printed on it?
MarkYu (author)fozzy132014-06-07
You are correct. If you want real Carbon Fiber, you'll need a mold, epoxy, Carbon Fiber sheets, and other stuff.
fozzy13 (author)MarkYu2014-06-08
MarkYu (author)fozzy132014-06-08
Thanks for the feedback. I have fixed the title.
This is so cool, I want to do that, what kind of phone did you carbon fiber?
jsrubianoch (author)2014-06-06
Really nice and simple, great Instructable!
About This Instructable
28,292views
87favorites
Bio: Hi, I'm Mark! I make Instructables of things I find cool so follow me and check my stuff out! :)
More by MarkYu:DIY KeySmart/Key OrganizerUltimate Travel HacksHow to "Carbon Fiber" Anything
Add instructable to:
