Introduction: How to Care for Your Betta Fish
Picture of How to Care for Your Betta Fish
Betta fish are known for being tough, but that doesn't mean that you should neglect them. Caring for a betta if fairly easy, and if you do it properly, your betta will live a long life and it will be well worth it.
Step 1: Picking Your Fish
Picture of Picking Your Fish
Betta fish come in many different colors and patterns, so sometimes it is hard to tell if the fish is just a pale color, or if it is unhealthy. if you follow this key, you will most likely take home a healthy fish.
1. A betta fish should be brightly colored. Some fish are naturally pale, but it is usually easy to tell those from sick fish. If the fish looks grey and speckled, and the tips of it's fins are colored, that indicates that the fish was once a different color and is probably not very healthy.
2. A fish should not have holes in it's fins. Bettas sometimes have "stringy" fins, but if the strings seem irregular or if there are holes in the fins, this may mean the fish is sick.
3. Eyes. The fish's eyes should be healthy and shiny, which is sometimes hard to see underwater. However, if the eyes are really bad, you will be able to tell.
4. The fish should respond to you waving your hand in front of it. Fish do not like it if you tap on the side of the tank, so waving your hand a few times is a better alternative. If the fish moves, it's probably healthy.
Remember, it's okay to get a fish that doesn't look 100% healthy. Pick the fish you like. Besides, it will probably perk up once you get it into warmer water, in it's new bowl.
Step 2: The Tank
Picture of The Tank
Betta fish are famous for not needing a filter in their tank. Instead, they get oxygen from the top of the bowl. Bettas are also famous for being able to live in small spaces.
Requirements:
1. Plants- bettas like to rest in plants. You can use fake plants, or buy real ones. Make sure they come from the pet store, and are meant to be underwater. Other plants, fake or real, can poison your fish. I also do not recommend using "betta bulbs," because they can grow fungus and poison your fish.
2. Size- Bettas can live in small spaces, but they will be uncomfortable in anything less than a half gallon. 1 gallon is probably ideal. If you have more than 5 gallons, you need a filter.
3. Cleaning- You should clean your betta's tank once every week. Make sure you rinse the gravel and any decoration, and these things can get dirty and make your fish sick.
4. Water temperature- Bettas are considered tropical fish, so they are most comfortable in warmer water. The water should be between 70 and 80 degrees.
5. Do not put your tank in direct sun. This is bad for the fish, and will aggravate it.
I don't know much about this, but bettas are sensitive to the pH levels, so it might be good to invest in a pH test kit for the first few weeks that you have your fish. If the levels remain normal, you will not need to test anymore, but of the levels fluctuate often, you may need to change something on your tank.
Also, keep male bettas separate. There are tanks that come with dividers to keep your fish separated. You can however, have as many as 5 female bettas living together, and 1 male with them, as long as they don't fight.
Last of all, wall mounted tanks are hard to clean, so if you want one, make sure you have a way to maintain it.
Step 3: Feeding and Cleaning
Picture of Feeding and Cleaning
Do not feed your betta tropical fish flakes. These are bad for them. Instead, feed them betta pellets, brine shrimp, or bloodworms.
When you clean the tank, do not take out all the water. Take out about half, then replace it with clean. If you do take out all the water, let it sit for a little while before putting your betta in.
Step 4:
Picture of
I got this from Yahoo voices. I DO NOT OWN THIS INFORMATION.
1. The Labyrinth Organ
The most unique thing about the betta fish is it's evolution of a labyrinth organ. Located at the top of the betta's head, the labyrinth organ allows the betta to breath air from the surface. There are over 72 types of fish who have this special organ; most of which originate in the shallow waters of Africa or Southeast Asia, where low water depth and high temperatures result in low oxygen saturation in the water.
2. The Appearance
The betta fish as grown in popularity in large part due to it's appearance. Siamese fighting fish is found in more than 25 different colors and patterns. The most common colors are red, blue, turquoise, and white. When a betta fish is happy and healthy, it's colors become more vibrant.
The elaborate fins are also a trait of the betta fish. Male betta fish have long and flowy fins, while females often have shorter fins. There are seven different varieties of fin types in betta, the most common being veiltail, followed closely by crowntail. These two varieties are usually found in most pet stores.
3. The History
Betta fish are native to the rice paddy fields of Thailand (previously known as Siam, hence the name Siamese Fighting Fish), Indonesia, Malaysia, Vietnam, and parts of China. In the early 1800s, the King of Siam began to notice that his subjects were fighting these fish and began to regulate and tax the sport. Unlike western cock and dog fights, the betta fish fights were based on bravery, not injury. Spectators would bet on how long a fish would fight and which one would retreat first.
The betta fish of these fighting competitions were not the colorful, flowing fish that we know today. The bettas of the time were typically short-finned and mud-colored, valued for their fighting skills, not their beauty. It wasn't until 1927 that the first bi-colored betta's arrived in San Francisco. After that, people began breeding betta fish for their wide array of colors and fins, giving us the many varieties we see today.
Step 5: End
Picture of End
The End.
Have fun with your fish!!!
(you may want to look at other instructables on this topic, as I am not an expert, and others may have more information.)
Meowmixmeow (author)2016-12-27
Good lord. Half a gallon will kill a betta. 3-5 gal is good for a betta.
florence chen (author)2016-01-11
Is it okay to keep a betta fish in tap water???? I want to make sure my fish is ok:[
RachelM146 (author)florence chen2016-10-20
ONLY if you are treating with a water conditioner. There are several types out there so do some research.
littlerae57 (author)2013-05-12
They don't fight with other fish either (at least that is my experience). I had a bata for 11 years and he out lived 5 fan tail gold fish friends. He got depressed when they died... Just hovered at the bottom of the bowl till I got him a new friend :/ Betas are awesome fish ;)
Why the heck did you have five fantails with a betta in a bowl?!? Fantails need 20 gallons to start, then add 10 more gallons for each fish. And they do best in different conditions. Fantails prefer fewer decorations due to being clumsy swimmers while bettas love silk or live plants to hide in. Bettas need warmer water, around 78 degrees Fahrenheit, while goldfish do better in cooler temperatures. Also, goldfish create a lot of waste, which builds up ammonia, a chemical deadly to both bettas and goldfish. Sometimes, if all of the conditions are right, then bettas can live with lots of other fish-example: my oldest betta, Anthony, is very mellow, so I have him in my 60 gallon high tech planted tank with plenty of hiding spaces, regulated water temperature, a very powerful canister filter, and proper food. But bettas and goldfish are not good tank mates, and unless you have a 70 gallon bowl with a powerful filter, then that is not how you take good care of fish.
pollyanna32 (author)2015-09-07
what is the correct temp for a male betta, and will one gold fish be compat able
78 degrees is good for bettas... and goldfish are not compatible-first off, unless you have a very mellow betta, they will fight, second, even smaller types of goldfish need at least 20 gallons (Don't put one in a .5 gallon tank with a betta) and lastly, they require many different circumstances such as different types of food and bettas being tropical fish needing warmer water while goldfish do better in cooler water.
AzelP (author)2014-12-11
Always have a hieing spot for your fish no matter what kind you have, fish tend to spook easily and you can stress them out and possibly kill them.
Bobey (author)2014-04-09
If you need help with fantail goldfish I have an instructable
jmichael21 (author)2014-01-31
I have a vt. Beta and a ct. Beta and I would like to mate them but I do not know if it will kill the baby's or not.
And will a boy beta kill a goldfish or not ?.
About This Instructable
54,610views
31favorites
License:
More by HorseGirl774:How To Care for Your Betta Fish
Add instructable to:
