How to Cast Molten Aluminium Into a Solid Slingshot
Published
Introduction: How to Cast Molten Aluminium Into a Solid Slingshot
Hey guys,
Today I am showing you how to cast a full aluminium rambone style slingshot using the lost foam casting method. This video took loads of time to make and if you enjoyed it you may want to check out my other casting videos here
Rambone slingshot files
Enjoy the video and good luck if you do try this!!!
Disclaimer:i hold no responsibility for any damage or injury caused if you try to re create this weapon.if you do make this weapon be safe and always wear glasses when using it.always use this weapon in a safe and controlled environment where no one is in danger because of your actions!don't be an idiot!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    4 Comments
    What's on the pommel/hand
    Impressive, a very well made video, and an interesting project, One suggestion, put a "sprue" on the end of what you cast; that might help you get the end cast. You can estimate the amount of material you need to cast by putting the form in a container --- filling with sand to a known volume --- then removing the form. The difference is the amount of casting material needed. --- you will probably need to add some extra for the sprue and loss. .
    I love the casting method. Well played. thanks for the video.
