3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Cast a Face in Plaster
Step 7Patch the holes
Patch the holes
  • last photo ←
Working from the outside, use a couple more small plaster strips to fill in the nostril holes. Do this from underneath so the mold doesn't have to turn upside down.
Once that's set, mix up a little more alginate (a teaspoon or less, really you need very little) and patch the inside. Cover the plaster that will now be showing through the nostrils - if your alginate is not too loose, you can build this area up a little to be more nostril-y and undercut.
You can also patch any areas where you had bubbles underneath, or where the alginate tore, or was a little too thin. The new set of alginate won't stick all that well to the set alginate, so it's not suitable for very large patches. But small patches work just fine and are much less noticable on the finished casting than blobs of plaster sticking out into an air bubble.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
242
Author:rachel
I'm a founding member of Noisebridge (https://noisebridge.net), a hackerspace in San Francisco, and Ace Monster Toys (http://acemonstertoys.org/), in Oakland. If you're in the area, stop by and say h...
more »
