How To Change Lawn Mower Oil by toolrepair
Step 3: Replace the Oil Filter (if applicable)
The majority of walk-behind lawn mowers do not have oil filters, but several models on the market include them in the engine design. We've included the steps for changing a mower's oil filter below in case your mower model includes one.
If your lawn mower engine model does not include an oil filter, skip to step Step 10 to complete your oil change.
6. Prepare something to catch the oil.
Unscrewing your mower's oil filter will spill the oil it is holding inside of it.
Container to Catch Oil
Find something to catch the oil that is small enough to fit under the filter as you unscrew it.
Postion Container
7. Unscrew the old filter.
The old filter simply unscrews.
8. Coat the seal of the new filter with oil.
The seal of the new oil filter needs to be coated with oil before it is installed.
Using your finger, apply a small coat of motor oil to the outside lip of the new filter. This thin coat of oil will ensure that it seals tightly when you install it.
9. Install the new oil filter.
Screw the new oil filter into place until it touches the plate it seals against. Then, give the filter a firm 1/4 or 1/2 turn to tighten it down.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
