How to Change Nissan Micra Interior Light
11,725
6
Published
Introduction: How to Change Nissan Micra Interior Light
Here I'm going to show you how to change your interior light on a Nissan Micra K12 to LED.
Step 1: Removing Light Fitting
Insert a flat head screwdriver or with your fingers, pry the fitting away from the roof lining.
Step 2: Adding the New Bulb
Simply push the bulb to one side and slide the old bulb out and then reverse the removal to add your new bulb.
If you're adding an LED, remember to check the polarity. If the bulb doesn't work at first, change the bulb round and it should work!
Step 3: Final Step
Push the light fitting back into place, slide the front in then push the rear part up and it will click into place.
Success!
      • Stick It! Contest
        Stick It! Contest
      • Pets Challenge
        Pets Challenge
      • Make it Move Contest
