Beside the instructable i shared with you the video version of this how-to / instructable , witch will make it more easy to understand and more entertaining !
You will need only a bottle of water, and access to a printer , the method is not well known but the efficiency is incredible !
Enjoy !
Remove these ads by
Signing UpStep 1Step 1 - Cheat Sheet
Well i recommend that you print your sheet with "Times New Roman" on a small font size 6 or 7 depending on how it's more comfortable for your view ! you could hand write your sheet but it's way harder to understand printing is the best option !
Make sure your cheat sheet dose not exceed "5cm height and 10 width" .
¥_¥
Your bottle trick is very clever, but the biggest drawback is that if you're caught, there's no way to destroy the evidence.
You could also write stuff on an eraser (assuming it has a shell/sleeve of some sort). Far, far less space, but if you're at risk of being caught, you can smudge your notes and destroy all evidence.
Also: sans serif fonts will probably be more readable at tiny point sizes. I can comfortably read 4pt Arial (slightly smaller than 5pt TNR) through my soda bottle 8" away, but 5pt TNR is harder.
*other fun topics are:
- if the floor started caving in, how could I save myself?
- if I were told that zombies have invaded, what would I do first?
- if I had an essay to write, what other preposterous questions could I come up with to procrastinate?
