How To Clean Guitar Or Bass Strings
 by x_xPacox_x
video How To Clean Guitar Or Bass Strings
a little vid on how to clean guitar or bass strings (WARNING: I SEEN VIDS OF PEOPLE BOILING STRINGS TO CLEAN THEM, IT WILL CAUSE THE STRINGS TO RUST, DO NOT ATTEMPT)
tubajoey1 says: Jan 15, 2009. 10:02 PM
While a novel idea, the way you did it could harm the instrument. when removing strings, especially on a bass, it is important to do them one at a time. this is because the neck is made to have the force of the strings pulling on it, and when you take those away, it will want to go backwards (in the direction opposite where the strings sit). it works the same way for guitars and all other string instruments that i can think of. while i have never heard of anyone taking the strings off to clean them, i guess it works. personally i use an alcohol based cleaner and a soft rag or tee shirt on my bass. generally that is the safest way to go about it. and if your strings are dirty to the point beyond that cleaner doing much, new strings are the way to go. good video, slightly unorthodox way of doing it. i did like the part about cleaning the g string though...i giggled.
arcane2rox in reply to tubajoey1Dec 23, 2011. 9:47 AM
Before i knew better I took all the strings off my 5 string to change them, and even if it didn't damage the instrument I took forever to get the damn thing tuned properly, especially with the massive amount of tension behind a B string!
1spartan95 in reply to tubajoey1Jan 9, 2011. 7:00 PM
While a novel comment, thats a load of baloney
theskimlife in reply to tubajoey1Sep 8, 2009. 2:33 PM
Although your right about how taking the strings off gets rid of the tension to counteract the torsion bar, but the force is minute. It will really only have an adverse effect if you leave the instrument stringless for something more like a day
ToxicPinkPoison in reply to tubajoey1May 29, 2009. 5:58 PM
Actually, removing all the strings at once is perfectly fine, as long as you are replacing them almost immediately. It only cause's a problem when your leaving them off for a long period of time. In witch case you would have to adjust the truss rod so that it does not stay back bowed when you restring it later.
LargePaperCup says: Aug 17, 2009. 4:21 PM
couldnt you just buy new strings?
x_xPacox_x (author) in reply to LargePaperCupDec 17, 2010. 9:06 AM
Couldn't you buy a real guitar pick hanger
harryburke360 says: Feb 24, 2010. 9:42 AM
does  he only have 3 fingers???
wtphackes says: Dec 5, 2008. 12:25 PM
okay i can understand that you did this with your bass strings (guitar strings are cheaper) But your way to fix the strings on the tuners an the head(sorry i just know the german word Stimmwirbel :D)) is totally horrible
x_xPacox_x (author) in reply to wtphackesDec 5, 2008. 4:29 PM
(removed by author or community request)
wtphackes in reply to x_xPacox_xDec 6, 2008. 5:23 PM
Ich möchte dir nur damit aus erfahrung sagen, das diese knotenkonstruktionen recht instabil sein können und so nachweislich sich dein bass wesentlich schneller verstimmen kann. Ich hatte das bei meiner gitarre zur anfangszeit früher auch gehabt, einmal sogar ist mir beim spielen die saite vom saitenknoten abgerutscht d.h. Vom e tuning war sie ungefähr schlagartig auf d#
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
