There are spray "contact cleaners" available for this purpose, but in most cases just mixes the dirt and grime already inside with more dirt and assembly grease and may make the control operate worse than it is already.
Remove these ads by
Signing UpStep 1Remove mounting knobs and nuts
I followed your instructions and dared to take it apart to clean the volume pot.
Now I have a new amp!
Thank you for your superb clear instructions and pix.
Now how did Stairway to Heaven go? (only jokjng!)
Cheers,
Myles
I was wondering if I could use this same technique with the nobs on my numark mixer as Im a Wedding DJ in Melbourne. And my mixer makes crackling noise when I raise the volume. If anyone can recomend a product that would be great and save me from buying a new mixer. Cheers
So be careful you dont do this too often
If they are using things like sandpaper on it, then you need to take it away, as well as any sharp objects, before someone or something gets injured. As said below; if a blast of "TV tuner cleaner/lube" or similar product, followed by moving it through it's range-of-motion several times does not solve the "scratchy pot", then just replace it, as the brush or substrate may simply be worn-out.
Automatically replace it if the maximum resistance is not within 10% of it's rating (or 5% for motor speed-controls and non-television audio equipment is my standard). If there is a lot of "play" in the shaft of a radial varistor (indicating wear), just replace it.
For cleaning contacts like nintendo cartridges or audio jacks, etc., denatured alcohol is perfect.
"Exercising" you pots means to periodically run the pot back and forth through the entire range of motion so that oxidation has less of a chance to take hold in any given area. Indeed, you can even "exercise" a scratchy area completely out of existence with this method. I resurrected a rather expensive fender amp ( and got a deal in the bargain ) with a complete set of scratchy pots by turning it on, playing a tone through it, and then running the pots back and forth until the scratchiness went away.
Basically the wiper in the pot abrades away surface oxidation that causes scratchiness. This is fine for your amp because these pots are designed for thousands of turns through the course of their lifetime.
As an aside there are electronic problems that can cause pots to sound scratchy as well. Most commonly DC leaking on to the pot from a bad capacitor so that is worth checking to especially in old tube amps. Some modern guitar FX pedals exhibit these symptoms while working normally like some Zvex and other boutique distortions that use a pot to voltage starve the circuits but the pots are usually marked "crackle ok".
Especially for tube amps, and for any electronics using large capacitors and/or large power transformers in general... PLEASE BE CAREFUL. Discharge those capacitors first safely. Don't work with amps that are powered on. If you've never done this before, learn basic electrical safety first. Be safe! :-)
I'm currently going through the exercise of finding one of those one-of-a-kind pots with an unusual resistance, unknown taper, and attached AC switch for my old reverb unit--one of the best arguments there is for the method you so clearly show here, rather than "simply" replacing the pots.
I have used spray contact cleaner on my old Fender amp with mixed results--as I recall, the pots are not soldered to a PC board, so eliminating the de-soldering/re-soldering steps should make it a whole lot easier. I've also run across some pots that don't have much of an opening anywhere to spray in the cleaner, even with the little red straw.
Comments about the jack also seem right on target to me, also. The guy I bought my amp from said it had been in a basement (dampness) for a while and the jacks seemed "dirty", (noisy), so he "cleaned" them up by sticking in a fine rat-tail file into the jack holes !! (Takes all kinds). I'm trying to find some gold-plated replacements, if I can afford them, which should take care of any future worries about corrosion on the jack contact surfaces. I also need to deal with the "death-cap", which I might post as an instructable, if nobody else has yet.
Thanks for sharing this. I never thought about disassembling the pots, but it looks pretty do-able.
I wouldn't use the side-load ones, just the top-load ones like this one:
Another idea is to use q-tips (or paper towel) with 93% Isopropyl Alcohol
(off the shelf) to clean away the flux residue left over from desoldering. That
will help immensely in your visual inspection.
I used to fix Fender amps back in the 90's. The small solid-state practice amps
were notorious for "intermittent" connections at the board. They were used by
kids who's cords were proverbially short....
Also, a case can be made that it's a "greener" method since you're not using up and discarding copper wick. OK, it's a trivial amount, but still...
in a pinch to get through the weekend would be an OK gamble but I would not want to rely on it to be a long term fix.
Murphy's law lives on stage
I repaired a power amp for a musician long thin wood shavings from a cut off saw had gotten in and under the slider it was more reliable to replace
good skill and patience
I mean. for the purposes of illustration and context of understanding
the wiper mechanism of a potentiometer; no it’s quite relevant. That said;
I truly believe a bit of DeOxit (my pref. contact spray) and some air in a can
can clean the pot indefinitely. If it’s an issue with a contact - re-solder joint.
I’ve never found it necessary to open a potentiometer wide open in any circumstance! Thanks for sharing though!
This is a bit of work, so I usually try a cleaner/lubricant first. A plain cleaner may remove the carbon and change the value of the pot or destroy (cheap) pots. I use plastic safe cleaner/lube so I don't have to worry about over spray eating the other parts.
Radioshack had some stuff called TV-Tuner/Control Cleaner & Lubricant cat no. 64-4315 ($10) but I use the equivalent CRC 2-26 Plastic Safe Multipurpose Precision Lubricant -you can get it at many hardware stores. (Home Depot - $3/can)
I use the plastic straw to spray just a little into the little hole at the back of most pots - the opposite end from the solder terminals. I don't usually clean/lube the pot shafts unless they are too hard to turn. Cleaner in the shaft will remove some of the grease that's in there.
Then when the cleaner/lube doesn't work, I follow this instructable. :)
For step 2, I usually mark the pot and the PC board with a permanent marker with numbers so I can keep them separate. Or mark them with their function (vol, tone, etc.)
