3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Clean The Controls On Your Amplifier
Step 3Remove old solder
Remove old solder
Remove old solder and inspect the pads for any burnt or broken traces.
5 comments
Sep 14, 2010. 5:23 AMfun2fix says:
On this step: If you can afford a solder sucker (ie; Solder Pullit) It saves a lot of time. If done correctly, it will keep you from lifting pads and etches. It does a great job of evacuating the solder from a thru-hole. Using solder wick works great for surface mount components and some through-hole but you will end up leaving heat on the pads longer than needed. I use both and each do their job in the right places.
I wouldn't use the side-load ones, just the top-load ones like this one:
Sep 14, 2010. 5:11 PMfun2fix says:
Absolutely! If you don't have the luxury of an inspection light (with lens) or an eye loupe you have to use the best technique you have.
Another idea is to use q-tips (or paper towel) with 93% Isopropyl Alcohol
(off the shelf) to clean away the flux residue left over from desoldering. That
will help immensely in your visual inspection.
I used to fix Fender amps back in the 90's. The small solid-state practice amps
were notorious for "intermittent" connections at the board. They were used by
kids who's cords were proverbially short....
Sep 14, 2010. 5:18 PMfun2fix says:
Since I can't re-edit what I said, You already mentioned the alcohol... :-)
Sep 14, 2010. 6:41 AMfdmundo says:
I totally agree with fun2fix -- I never got the hang of solder wick and ruined many a PCB with it. Solder-suckers work consistently well for me. Just put a little container under the bench to catch the expelled solder when you "reload."
Also, a case can be made that it's a "greener" method since you're not using up and discarding copper wick. OK, it's a trivial amount, but still...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Teslaphonics
