3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Clean The Controls On Your Amplifier
Step 8After cleaning - reassemble the control
Being careful not to forget any parts, recrimp the case making sure not to bend the case or trap any parts between the case and the parts inside.  Turn the control and check for a nice smooth motion from the 0 to 10 locations.  The control should move approx. 120 degrees without any binding or bumps.
If you think you assembled one incorrectly, set it aside, and open the next one to look at how it should be assembled to fix the last one.  If you need to, take pictures of each phase to help you reassemble the parts later.
Try not to get any grease or oil on the contacts while assembling the part.  There may be some grease on other areas of the control, but it is not intended to be on the contacts.  There is a special conductive grease that can be used on the contacts, but is not necessary for proper operation.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Teslaphonics
