3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Completely Disassemble a MAC Mouse - Clean/Repair/Mod
Situation:
Your MAC mouse scroll ball is not scrolling correctly, whether it be down as in my case or up or around in general.
Action (Multiple Choice):
A) Buy a new mouse.
B) Clean the little bugger.
C) Only use the track-pad (Laptop only option)
D) Slam the mouse around and hope to dislodge the dirt. Usually resulting in only Option A as the choice.
This Instructable is for those of you would like to clean, mod, or otherwise see how the thing works without destroying your MAC mouse, hopefully. It's broken anyway, so what do you have to lose.
Contrary to some research and references that I have read online, a dremel is unnecessary. I used the dremel during my repair process to carve out the Apple symbol on top of the mouse.
Best of luck.
Tools:
An Exacto knife or sharp knife from your silverware drawer.
A small tipped Phillips screwdriver.
A small tipped Standard screwdriver.
A multimeter if you fancy making sure the 5v power connection is still working properly.
A small amount of quick dry glue or super glue.
Patience, patience, patience.
Step 1Tools and Completed Disassembly
The tools used are pictured.
The disassembled mouse is also shown for reference.
9 comments
May 4, 2012. 5:25 PMiApple guy says:
Do you know why they put a pizo buzzer on that board? I have neaver heard a apple mouse make sounds!?!?
Oct 19, 2010. 5:34 PMbricabracwizard says:
I have had to use the mouse with no scrolling action - I really like your instructable, very clear pictures. I tried something else which worked for me, I sprayed lots of electronic cleaner through the hole where the ball sits (using plastic safe electronic cleaner) held the mouse down (do this with the moused unplugged) and rolled the ball quite vigorously and using a lint free cloth to wipe up the gunk that came out of the hole and my mouse has worked perfectly since.
Jun 22, 2010. 10:07 PMPSPerson says:
although i do like this guide, i think you might be better off springing for the magic mouse. i have used the mighty mouse (brand new and crudded up at the library) and i own a magic mouse, and the magic mouse beats the mighty mouse any day.
May 12, 2010. 6:46 PMmsd-boston says:
 Thanks so much for this. I've struggled mightily w/ bad scrolling, but can now save at least one mouse-buying episode (depending on how hard it is to get the plastic ring off again once super-glued).
One possibly helpful note is that if you're just trying to fix scroll wheel, you don't need to disconnect any ribbons or unscrew boards (you can skip steps 3-4). It's easy to access the three screws of the ball enclosure, lift it out, and clean/air-spray it's innards. Worked for me.
Love the dremeled logo.  :)
-M
Dec 11, 2009. 6:29 AMgalb says:
very very good. my original idea was to make it a backwards mouse so everything was backwards but there was the problem of clicking which was impossible so instead im making a custom body out of a mint container and i will be put up a instructable for that =).
one suggestion thoe would be stating to slowly take the top off the bottom i didn't and i ended up breaking a little green wire. not sure what it does because i plugged it in and it worked just fine.
Thanks soo much for this awesome instructable
Jan 30, 2009. 11:30 AMWalkerYYJ says:
Awesome! Thanks!, there is however something else people may want to try before undertaking this one, unplug the mouse (or turn it off if its bluetooth) Then get a clean piece of paper, turn the mouse upside down and firmly roll the ball around on the paper...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:hemlocke
