3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Connect a PS/2 Keyboard to the iPhone
Step 11Finishing Touches and Future Work
To finish up, reconnect the lead from Pin 13 on the iPhone breakout to the TX pin (pin 1) on the Arduino.  Disconnect the USB cable and switch the Arduino to external power.  Plug the iPhone breakout into your iPhone.
If:
  • TouchClient is running on your iPhone
  • The PS2 software is running on your Arduino
  • The Keyboard is plugged into the connector, and the connector wired to the Arduino correctly
  • Veency is running and you have accepted the connection from TouchClient
  • Nothing else is screwed up
You should be able to type on the PS/2 keyboard and have those keystrokes translated to the appropriate iPhone keystrokes.  This will work anywhere in the iPhone, in any app or native feature.
This solution isn’t perfect, but it’s a general-purpose approach to using the Arduino to add PS/2 keyboard support to almost anything that can read simple serial messages.
Future work:
  • The scan code mapping could be moved entirely to the iPhone, and the hardware part of this project could be reimplemented on a much cheaper and lower power consumption chip, like a PIC.  This would reduce the cost of the unit by about $30, although it would require a PIC programmer.
  • Not all special keys are correctly mapped, but if you look in the Arduino code and then at the iPhone code, you’ll see that this is an incredibly simple process.  Please post any changes you make back here as a comment!
  • Rather than being a crazy wire hack, I’d like to see this fit into a snug little enclosure for real portability.  Any ideas in this department would be appreciated.
  • I would like to give TouchClient a password for Veency so that there isn’t that annoying Accept/Decline pop-up.
  • This exact method could be used to add a Bluetooth keyboard.  Simply add a Bluetooth-Serial module to the iPhone breakout and keep using TouchClient & Veency.
That’s it.  I hope you enjoyed the Instructable!  Looking forward to your comments.
Regards,
- awgh
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:awgh
