3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Connect a PS/2 Keyboard to the iPhone
Step 2Solder the iPhone Breakout - Part 2
I’ve put the jumper between pin 11 and pin 16 on the back of the breakout board.  It can be a bit tricky to fit everything on to pin 16, so I recommend first sticking the resistor through the hole, then wrapping the end of the jumper wire around it and soldering them together before clipping off the resistor lead.
Another tactic which may be useful here is to first tin the ends of your wire, then blob a little solder on the hole you want to stick the wire to.  Use the side of the soldering iron to warm your blob of solder and the SLIDE the tinned end of the wire into the blob.  Remove the iron, let blob cool, then let go of wire.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:awgh
