3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To: Connect your Wiimote to your computer via Bluetooth
Did you know the Wiimote's capabilities reach far beyond the uses Nintendo is limiting it to? It's true, and in this tutorial I will show you how to connect your Wiimote to your computer and open up a limitless range of opportunities.
Most people don't know that the Wiimote communicates with the Wii via a Bluetooth wireless link. The Bluetooth controller is a Broadcom 2042 chip, which is designed to be used with devices which follow the Bluetooth Human Interface Device (HID) standard, such as keyboards and mice. The Bluetooth HID is directly based upon the USB HID standard, and much of the same documentation applies.
The Wiimote is capable of transmitting huge amounts of data to the Wii (Nintendo just isn't utilizing it's capabilities thus far). By using the internal Bluetooth wireless link, you can connect your Wiimote to your PC (any OS), and use it with a wide range of applications already made for the Wiimote.
So check out the next step and I will show you what you need to do.
Note: If any of you are having difficulties with this, just send me a message here. I'll be glad to answer any questions you may have.
Step 1What you are going to need
First, you need to find out if your computer has an internal Bluetooth adapter. While some desktop computers have an internal Blutooth adapter, most require an external Bluetooth dongle. Most recent laptops come with a built-in Bluetooth adapter. To check if you have a built-in adapter, look at your PC specifications.
Note, if you need a Bluetooth adapter, I recommend buying one here . That's the exact same one that I use, it's cheap and it comes with the BlueSoleil driver 2.6.0.8 on an installation disk.
If you don't have BlueSoleil already installed, you can download the latest BlueSoleil drivers from their website
Also, you're obviously going to need a Wiimote to connect to your computer!
102 comments
1-40 of 102next »
Apr 4, 2012. 11:40 AMNathsem says:
Hi, I have tried this over and over and over again and it hasn't worked. Here's a screencast of me trying to get the WiiMote and my Laptop paired up to play games using Dolphin: https://www.youtube.com/watch?v=ANcOeAnySp0
Mar 15, 2012. 11:53 PMShade95 says:
Hey, i have my wiimote appearing and everything, but when i connect it, it just stays on the connecting stage forever. Im using BlueSoleli 8.
Feb 7, 2012. 11:22 PMcrown3DS says:
thanks for your sharing,i bought my Wii Bluetooth Wireless Remote and Nunchuck Nunchuk Controller from http://www.digitopz.com/wii-bluetooth-wireless-remote-and-nunchuck-nunchuk-controller-p-156.html , and follow the guide you shared,it works . Thx ~!
Sep 30, 2011. 2:36 AMkswaminathan says:
Can i keep 100% belief on this? Will it work?Can i buy the wii remote believing this?
Oct 11, 2011. 2:47 PMacosmicist says:
It depends specifically on what you believe about it. If you believe that you wil be able to use your wiimote as a pointing devices solely by the bluetooth connection, you have very wrong beliefs.
You'll be able to connect it as a HID (Human Interface Device) - but in order to use it as a mouse pointing device, you have to have some way of transmitting the sensor bar data to your PC
Dec 8, 2011. 2:23 PMpsphaxzor says:
the sensor bar doesn't transmit data.
Dec 12, 2011. 1:58 AMacosmicist says:
I'm aware of that...
I don't know why the hell I said it like that.
What I should have said was that he'd need a sensor bar of some kind in order for the wiimote to detect its own orientation and transmit that data to the PC.
Thank you for pointing that out, though.
Sep 27, 2011. 7:31 PMDallins11 says:
cool!!!
Aug 22, 2011. 2:43 PMKozar says:
Is there possibly a freeware bluetooth stack that can operate with the bluetooth dongle in this instructable? (that's the same one I have)
Apr 15, 2011. 4:58 AMpietzeekoe says:
Will one of them mini bluetooth dongle work?
Feb 12, 2011. 12:31 AMzack247 says:
i just got a new-ish laptop, it has bluetooth built in and im going to try this!
Sep 9, 2010. 9:06 PMComputothought says:
Bought a coupple of cheap bluetooth adapters when fry's was dumping airlink for about 5 bucks each. I think I have a wii controller clone. Worked just fine with linux.
Sep 23, 2010. 10:34 PMelmanual says:
it worked fine on my ubuntu machine but its a nyko brand it wont work on my win7 machine.
Sep 24, 2010. 2:59 AMComputothought says:
The little time I played with 27, I found a lot of things that will not work with it. to be honest, we have been MS free for almost 4 years. I do not have an mswindows machine to test it on.
Sep 7, 2010. 5:51 PMcraig3 says:
Just by coincidence, i bought the same bluetooth thing as that, got it today but when i try to set it all up, on the last step rather than being the green line and all finished, on the green line is a red arrow that follows the line from remote to the orange orb, and the wii remote lights flash constantly, is this normal?
Sep 8, 2010. 7:26 AMcraig3 says:
I appreciate the help, but unfortunately it didnt really work.
Is that red dot think move up the line meant to be there?
Jul 6, 2010. 10:15 PMelmanual says:
Does it have to be a real wii controller or can it be like a nyko wii controller cause it works on my ubuntu machine but in window it disconnects all the time and i cant find whats wrong.
Jun 2, 2009. 7:37 PMwharjj01 says:
I cant connect my wii remote to my computer please somebody help. I can't skip the passcode process and do not know what to do.
Mar 1, 2010. 1:27 PMWinko says:
No passcode needed
Feb 18, 2008. 12:09 AMvivchawda says:
do i need a wii or will the wiimote work without it??
Mar 1, 2010. 12:55 PMWinko says:
WiiMote will work without WII
Regards,
WInko
Jan 19, 2008. 9:34 AMItsTheHobbs says:
pc only? if it is my mac is too good for this
Mar 1, 2010. 12:54 PMWinko says:
MAC and WiiMote works, no GlovePie there. But PureData works
Regards,
Winko
Jul 26, 2008. 12:44 PMJoanassie says:
(removed by author or community request)
Aug 17, 2008. 8:42 PMflymudpie says:
Not every knows that so be a little kinder next time.
Aug 2, 2008. 2:21 PMItsTheHobbs says:
That wasn't very nice, and I take "get a brain cell transplant" as an insult. (Even though a single brain cell wouldn't make a difference) I also do not understand how I, as one tiny person, could send my brainwaves, and make people start killing people.
Aug 8, 2008. 5:22 PMJoanassie says:
Sorry, I was having an off day and felt annoyed. I think, though, that I meant people would copy your ignorant habits when I said "before your ignorance spreads". I happen to occasionally get angry.
Aug 8, 2008. 5:28 PMItsTheHobbs says:
Yeah, I have really bad off days.
Aug 8, 2008. 5:25 PMItsTheHobbs says:
I bet I can have a more off off day than you and get angrier!
Oct 17, 2008. 7:12 PMspock155 says:
-scoffs- internet trolls
Jun 12, 2009. 9:12 PMmage says:
dont feed the trolls
May 12, 2008. 6:16 PMJoanassie says:
way too biased for the tastes of anyone who isn't you.
May 13, 2008. 1:16 PMItsTheHobbs says:
Well, not just me, there are probably tons of people who would agree with me that in alot of ways, PCs aren't worth trying. also, Macintosh makes oh, well, lets see, ipods, iphones, all of the other cool i... things, which are all alot better than that thing you like to call Microsoft office. I support Microsoft in 2 ways only, gaming capabilities, and Xbox. My friend's PCs take like, 5 minutes to load, so we go do something else, while with my mac, it takes 5 seconds tops to load a page.
Sep 15, 2008. 8:31 AMDerin says:
PEACE TO MAC AND PC USERS!Mac users can put linux on their macs,and pc users can put linux on their computers,and we all will be same and this mac vs pc thing will stop.
Apr 18, 2009. 11:50 PMabadfart says:
ya and it just a hardware diff i once knew a guy that ran mac op a pc
Jul 26, 2008. 12:32 PMJoanassie says:
Yeah, but there are also MORE PEOPLE THAN YOU CAN COUNT who want to improve on PCs and the reputations of those PCs. Also, Macintosh is an operating system and Apple Computers makes iPods and the special model iPhone (you forgot the proper capitalization), which CANNOT be fairly compared to that thing that I myself don't like to call Microsoft Office because those are different categories, hardware like iPods and software bundles like MS Office. I support Microsoft in the same one way you do: video games (it's redundant and therefore repetitive and unnecessary to put X-Box (you really have to learn proper capitalization) in the sentence). My Windows XP operating system (you WERE talking about your friend's operating system, obviously, since you didn't mention any internet or browser whatsoever when talking about your friend's PC) takes like 15 minutes to load, so I leave it on all the time (tell your friend to do that with their PCs), so after power outages I use my emergency Windows XP system, which takes 5 seconds for the OPERATING SYSTEM to load up, while with my normal Windows XP it takes 20 milliseconds to load a page, and that's when my ISP shuts off my connection.
Aug 2, 2008. 2:28 PMItsTheHobbs says:
Huh, now thats something to say, 'cause I can count to at least 57, which is higher than that pathetic 5 you can. and, no dip! it was explorer, because thats the only junk that'll work besides firefox, which is awesome on my mac. stop filling up my comments while they could be good stuff. I really hate going back on old arguments, so go away and leave me alone!
Aug 8, 2008. 5:21 PMJoanassie says:
funny, I've been counting misspellings that I've seen on the Internet, and boy, it's way higher than your measly 57. It's exactly 13,742 as of right now.
1-40 of 102next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:The Uber Maker
