How To Copy Complex Curves! by snotty
Featured
That's right! Simply push it down and get a copy of a curve that might be hard to measure and copy otherwise. Not only is it hella useful but it's made from stuff you already have in your kitchen.
This is not my idea. It is a re-post from a forum.
Originally from: http://forum.miata.net/vb/showthread.php?t=448807
User: Godless Commie
It mimics a "profile gauge" tool but is made from bbq sticks and cardboard: http://www.amazon.com/Plastic-Profile-Gauge-Standard-Width/dp/B003A07NBG
Remember to rate this 'ible if you think it's useful :)
Bonus: A FREE 3 MONTH PRO MEMBERSHIP GOES WENT TO the first one to post an instructable of their version of this tool including a VIDEO. Post a link to that 'ible in the comments below. Yeah.
WINNER is Mr. Roshy10. Show him some love.
And a Warning from Wroger-Wroger: Be careful not to let stray bamboo skewers or their tips, skewer your foot. These bits can lurk in the carpet waiting to strike.
Step 1: Materials
Needful things
  • a bunch of bamboo skewers (or straws)
  • enough corrugated cardboard to cover your project
  • some sort of a marker, like a sharpie
antioch says: Nov 13, 2012. 6:51 AM
This idea is why I love instructibles
snotty (author) says: Jan 5, 2013. 6:11 PM
Glad to be of help!
ndr1968 says: Jan 5, 2013. 4:00 AM
I have been pulling out hair trying to come up with a way to trim out the hole to fit around the comode for new bathroom carpet. Voila! Here's the answer! Thank you sir, for the most usful instructable I have found to date!
Roshy10 says: Nov 5, 2012. 11:33 PM
http://www.instructables.com/id/How-to-copy-complex-curves-easily/
here is my version
snotty (author) says: Nov 6, 2012. 2:24 AM
We have a winner!
Roshy10 says: Nov 6, 2012. 8:16 AM
yay
vincent7520 says: Nov 4, 2012. 11:55 AM
Hollly F--- S --
I just bought one of these… and quite expensive.
Why didn't I think of it myself ???…
Guess I must be quite moron
congratulations !!!!…
AJMansfield says: Nov 5, 2012. 6:17 AM
Instructables apparently doesn't support utf-8 text.
AJMansfield says: Oct 30, 2012. 11:01 AM
You really ought to cut all the skewers to the same length for this.
jolshefsky says: Nov 4, 2012. 6:26 AM
I thought the same thing, but if you remove the contour gauge from the original, you can always copy from the side that makes contact with the original. If you want to copy from the other side, then equal-lengths would be critical.
AJMansfield says: Nov 5, 2012. 5:58 AM
True, true.
cammers says: Nov 5, 2012. 3:24 AM
Very nice. Brilliant use of common objects.
Wroger-Wroger says: Nov 4, 2012. 4:27 PM
Ahhhh the EVIL Bamboo Skewer - says Mr Genius Here, having left the odd one laying around, with the blunt end in the carpet and the pointy end sticking slightly upwards as it lay on the floor.
As I recall, about 40mm of it slid straight straight into the sole of my foot as it caught, when I was walking past......
Advise all the people to lay the skewers on a chopping board, and roll a knife or meat cleaver backwards and forward over them - near the pointy end, to remove it, by cutting through it pipe cutter style.
Nasty things, they just go straight through you.
Need blunt flat ends.
elic says: Nov 4, 2012. 2:08 PM
Very nice patent! I adopt it as is.
mikolynn says: Oct 30, 2012. 6:40 AM
Years ago I see something like this builded with metal to copy pieces using a lathe...
Anyway, good project!
kelseymh says: Oct 29, 2012. 9:28 AM
Very nice idea. Good on you for providing a citation to the original post!
This would be Feature-worthy if you took your own pictures, showing how you made and used the tool, and described your process in your own words.
The pictures you have included were simply copied from the original posting, as was most of the text (you left out the comments about smoking, but that's about all).
Did you get permission from the original author to use his or her photographs and text (all of which are copyrighted from birth)?
rimar2000 says: Oct 29, 2012. 9:19 AM
Clever!
Satrek says: Oct 29, 2012. 2:25 AM
Wow! I have a contour gauge at home, with small metal pins, and it works well for smaller contours, although I rarely ever use it. Your concept is so stunningly simple, versatile and scalable... Thanks for sharing!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
