Introduction: How to Create a Bedroom That Reflects Your Internal Shame
Picture of How to Create a Bedroom That Reflects Your Internal Shame
Do you find yourself ceaselessly tossing and turning at night in your bed of lies because you can’t seem to get those mistakes of your past or present out of your head? Do you have an inflated sense of self-loathing or masochistic tendencies that are begging you to draw even more attention to your latest sins? Would you love to torture your guilty conscience even more by combining your self-hatred with home décor? Well look no further because I have the project for you right here! Follow my simple steps and you’ll soon have the worlds most uncomfortable and ridiculing pillow and lamp shade to display in your home.
WARNING: Possibly offensive words are used as text on the pillow and lamp in this project.
Step 1: Materials You Will Need
Picture of Materials You Will Need
For this project, I’ve chosen the basic theme of “ADULTERY”. Since I am a flawless human being, I cannot relate to this problem but I shall try my best to imagine the torment it causes. The pillow I will create shall have Adultery themed words, made of a foam board material, jetting out of it, and the lamp shade, when placed next to a wall, shall project words of equal ridicule. (Please note that the items in the photo are only a small sampling of the materials you will need since I took this picture after the project was complete).
Here are some of the materials you will need:
Pillows:
- Fabric (if you decide to create your own pillow and pillow case)
- Quilt Batting (A package of 81” by 96” should be more than enough
- Needle, Thread, and Scissors
Words
- X-acto Knife
- Foam Board (20” x 30” x 3/16”)
- Sharpie/ Pencil
- Ruler
- Hot Glue Gun (Optional)
- Acrylic Paint (Optional)
- Paintbrush
Lamp
- Lamp Shade
- Lamp (or at least the base if you chose to use a Candle or Tealight, like me, for your light source instead).
Step 2: Sewing Your Pillow
Picture of Sewing Your Pillow
Although creating your own pillow and pillow case are not required steps, it will make your creation far more personalized and allow you to easily customize the size of your pillow.
For my pillow I chose a delightful teal fabric and measured it against a basic sleeping pillow I had lying around. This pillow measured at 20”x28” and its pillow case at 19”x30”. Since I wanted to make my pillow a bit larger I upped the measurements to 22”x32” (and 21”x35” for the pillow case).*
Since my given fabric was 44” in width and well over 32” in length, I decided to simply fold the fabric in half and use the folded edge as one of the pillow sides. This left me with two sides to sew now, and one to sew later once I’ve inserted the words and the foam board base they will rest on.
Since I wanted to give myself the most room when I do this, I chose to sew the two short ends of the fabric. While you can sew these ends any way you like, I wanted to give them a sturdy and tidy seal that will only be noticeable from inside the pillow.
The first seam I create, after threading the needle and tying the end, is a simple loop at the top of the fabric. I do this by placing the needle in the side of the fabric with the knot, pulling through the hole, and repeating until I reach the end. I tie off a knot and work my way back with my second style.
My second seam line appears like a dash mark beneath the first seam. I do this by placing the needle against the side without the thread knot, pushing through the fabric a little, directing the tip of the needle through the fabric a second time, and finally pulling the needle through. If you like, you can do a simple in-out-in-out pattern, however I find my way saves a bit of time. (Sorry if this is in anyway unclear but I’m purely self-taught in terms of sewing.)
Once you’ve sewn both ends, turn the fabric inside out. Your thread and needlework should be invisible and a nice, round seam should be all that is visible.
*My reasoning for these particular measurements is that I actually started with the pillowcase, which I merely boosted 35 inches from the regular pillow case’s 30. This was then reduced to 34 when I took an inch in to make a neater opening for the pillow case. So, wishing to keep the original pillow to pillow case differences to 1 in width (19” to 20”) and 2 in length (28” to 30”), I arrived at 22”x32” and 21”x34” for my versions.
Step 3: Sewing Your Pillow Case
Picture of Sewing Your Pillow Case
As I mentioned earlier, I chose 21”x35” for my pillow case measurements compared to the 28” to 30” measurements of my normal pillow case.
As with the pillow I folded my 44 width piece of fabric in half to make 22 inches. If yours is the same size you can cut off that extra inch or you can take an inch in with one of your seams.
Again, we are left with 3 open ends, but we will only be sewing one end (a short end, just like we did with the pillow) and tucking in a border on the other short end. The latter short end will remain open, as it is a pillow case, and like the pillow, the long end will be sewn once the board and pillow stuffing are inserted later.
Repeating the sewing techniques from before to create your seams from the first end of the pillow case. To create an open border on the opposite side, simply fold over an inch of fabric and sew that back into the fabric. Make sure to have the overlapping fabric on the side that will not be exposed.
Step 4: Cutting Your Foam Board
Picture of Cutting Your Foam Board
You’re going to divide your foam board into material for letters and material for the base. The base will be inserted into the pillow to act as a foundation for the letters.
I first cut out chunks of board for my words, each varying in length depending on the length of the word. However, the one constant you must keep in mind is creating a base portion to your words that can fit inside the pillow and will not be exposed. When I measured my pillow I found it to be about 2 ½ inches in height and thus gave each letter a 2 ½” base of blank space. While certain scissors may suffice for this task, an X-Acto knife will suit you best for any cutting or carving with the board.
Out of the remaining board I created a 20”x14” piece that I would use for the base.
Step 5: Writing and Cutting Your Hateful Words
Picture of Writing and Cutting Your Hateful Words
On each chunk you will write out your self-loathing words in block text. Make sure all of the letters connect in some way and remember that the dots of i’s or j’s will not work. Once drawn out, carve the word and any negative space out of the board.
My chosen words are: Slut, Cunt, Whore, Adultery, Loose, Greedy, and Hussy.
If you like you may leave your words blank, however I chose to create a teal color, similar to that of my pillow, by mixing acrylic paints and applied it to all of my words.
Step 6: Laying Out Your Words
Picture of Laying Out Your Words
Have a friend, family member, or highly intelligent pet help you out by tracing the space of your head unto the board, so you know where not to place your opposing words.
After this, select the best spots for your offending words to go. Remember the more uncomfortably close to your face the better! Mark the placement of each word’s base with a block of sharpie that is the length and width of the base, so you know what size to make the slot.
Step 7: Creating Slots for Your Words
Picture of Creating Slots for Your Words
Once you’ve created a satisfactory and aesthetically pleasing layout, carve out each marking with your X-Acto knife. Although you can cut all the way through the board, you may prefer to only penetrate the first two layers: the top “paper” layer and the middle foam layer. This will leave a bottom layer (the bottom “paper” layer) for the base of the word to rest on, rather than fitting through the whole board. If you choose to do this you shouldn’t have too much trouble as the foam is easy to scrape out of the slot without damaging the bottom layer.
Note: Just before you insert your words into the board, now would be a good time to mark on your pillow and pillow case where the words will be bursting out from the fabric. The simplest way is to place the pillow fabric over the board in a central position and use a pencil to mark each indentation of the board below. Next, place the pillow case on top, making sure to line it up as you will like to see it in the end, and make your markings. Cut out your new holes.
Once all the slots are cut, wedge the bases of your words in. Make note of whether you want your words to face inwards or outwards (this will decide whether you can read them or someone standing beside your bed) and make sure to tilt some of your words at uncomfortable angles. If you like, you can apply hot glue to the borders of your words to ensure they remain in place.
Step 8: Stuffing Your Pillow
Picture of Stuffing Your Pillow
Now its time to fit your base board and words into the pillow. Maneuver the board inside and slide your words into each corresponding slot.
Next, tear off and fluff up sections from your roll of quilt batting. Add the batting below the board, above the board, between the words, and into the corners. Make it as fluffy as you want, just be sure to have the fabric reach the base of the letters so the blank bases don’t show.
Once thoroughly stuffed, its finally time to sew up the only open side of the pillow. Keep in mind that we won’t be able to hide the seam this time since we can’t reach inside, however it will be hidden inside the pillow cover so sew as haphazardly as you like so long as the seam is tightly sewn.
Step 9: Fitting on the Pillow Case
Picture of Fitting on the Pillow Case
Finally, we fit the pillow case around the pillow and slide the words through the cuts in the fabric. Close up the long, open end, but remember that the seams will be exposed this time, so try to sew them up as neatly as possible.
Step 10: Creating Your Lamp
Picture of Creating Your Lamp
Believe it or not we have one additional, but much faster object of torment to complete, your lamp. This item will also display personally selected words of self-loathing (I have chosen Tart, Bitch, Slut, and Cheater).
First you must decide if you want your words to be projectable or read on the lampshade itself. If you want them to project, make sure you have a strong enough lamp or prepare to use an alternative light source, as I did. I found that the light bulb in my desk lamp created light that was far too dispersed, so I switched to a Tealight.
If you want your words to just be read on the lamp shade, trace out your block letters with a pencil and have at it with your X-Acto knife.
If you want them to project on to a wall you’ll need to write your letters backwards, then cut them out with an X-Acto knife.
Step 11: Additional Lamp Notes
Picture of Additional Lamp Notes
Additional notes for those who wish to project their words onto the walls:
- Notice what sort of walls you have. The lighter/ whiter in color, the easier it is for the words to appear. Also the closer to the wall it is, the easier it is to read the words.
- The light shining out from above the lamp shade may detract from the projection of your letters. If you wish to block this light out, extra foam board from earlier will suit you just fine as long as you don’t keep the light on for too long (if you’re using a light bulb). Place the board beneath the top of the lamp shade and trace its shape from within. Carve the board with your X-Acto knife until just the right size and wedge it in!.
Step 12: ENJOY!
Picture of ENJOY!
Now it’s finally time to set up your uncomfortable lamp and pillow in the bedroom/ artistic space of your choice! Savor the inability to enjoy proper lighting and say farewell the old privilege of turning your head at night without getting stabbed in the neck and face by foam board letters. You don’t have to thank me, I already know you’re welcome.
PeteFromOz (author)2012-02-08
OMG!... Can u use those words on the internet?
:p
About This Instructable
1,347views
1favorite
License:
Add instructable to:
