Introduction: Part Two: How to Create the Queen's Dolls House Strong Room
Picture of Part Two: How to Create the Queen's Dolls House Strong Room
Panelling and Railings
What you’ll need:
3017 Tudor- style wood panels
7373 Railings plastic 90x160mm
7172 white Skirting but could use 7018 which is untreated.
Tenon saw / Mitre block
Spray paint silver
Wood Primer spray paint
White spray paint
Pencil/ ruler
Wood filler
A small filler knife
Step 1:
Picture of
Firstly measure the panelling to whatever height you would like it it to be.
Using a ruler, mark up the panelling with a pencil draw a straight line across as a guide for cutting
Step 2:
Picture of
Using a mitre block and a small Tenon saw, cut along the line mark.
Step 3:
Picture of
Sand the Tudor-style Wood Panels with abrasive paper all over to remove any rough edges and to make a key for the paint to adhere to.
You can prime the panels if you wish to but I haven’t done here - purely for time purposes!
The Tudor-style panels are now ready for straying with white spray paint.
WARNING! Remember to always follow the instructions on the spray paint can. Always use the spray paint in a well ventilated area, covering up the surface area you are spraying onto.
Step 4:
Picture of
Once I had measured and arranged the back so the panelling was in-situ, I worked out how many 7373 Railings it would take to fill in the empty spaces. I tried to keep within the railing design to give the illusion that it was two complete gates. They are plastic and easy to cut using a pair of sharp scissors. Hang them on a stand to spray paint so that you cover all angles!
Step 5:
Picture of
Then once the 7373 Railings were dry, I then glued them to the back wall using a hot glue gun.
WARNING! Be careful not to burn your fingers when using the hot glue gun especially when gluing the railings as the hot glue can easily slip through the holes in the railings.
CONGRATULATIONS! You are now ready to work on the Queen's Dolls’ House Strong Room Display Stand
About This Instructable
546views
6favorites
License:
More by The Dolls House Emporium:How To Wallpaper The Front of Your Dolls HouseA Different Way To Use Your Dolls House!How To Install a Miniature Ceiling Rose with Wiring Tips
Add instructable to:
