Introduction: How to Cut an Avocado
How do you peel an avocado? I've seen many people try to peel an avocado like an apple. This will work, but if you apply my simple three step method, you can save yourself some time and energy.
Step 1: Cut Avocado in Half
Be aware of the pit when you are cutting. Slice in far enough to feel the knife hit the pit and then slide the knife around in a circle until the avocado is sliced in half. Pull two halves apart.
Step 2: Remove the Pit
Strike the knife into the pit.
Twist the knife and the avocado in different directions. The Pit should stay attached to knife and loosen from the fruit. As you pull the knife away, the pit should come with.
Step 3: Scoop Out the Avocado Meat.
Use a spoon. Scoop out the meat. Put it in the bowl.
Done your Avocados are peeled!
