Introduction: How To- Cute Duct Tape Bow
This is such a super cute and easy way to add some style to any kind of hairstyle....
Yes, I know it sounds really easy but it's worth it so I hope you guys all like it!
LETS GO!!!
Step 1: the Materials You'll Need Are...
1. Cutting mat (I got mine from Walmart for only about $8)
2. Ex-acto knife
3. Ruler
4. A bobby pin or some kind of clip so u can attach it to your hair (optional)
5. DUCT TAPE!!!!!! 1-2 rolls
Step 2: Cutting the Tape
Take your duct tape and cut a 7" strip of duct tape and a 6" strip of duct
It helps if you put your ruler against the tape and cut along the ruler so you get a nice clean edge
Step 3: Cutting the Strips That Hold the Bow Together
Once you have cut the tape set your six inch strip to the side. Then cut half of an inch strip of tape off of your seven inch strip of tape an cut the half strip of tape in half haha.
Step 4: The Body of the Bow
Now take your 6" strip and lay it sticky side up
and lay the longer strip of tape on it so the is about an inch of sticky showing on the top and about a fourth of an inch showing on each side of your six inch strip of tape.
Then fold the sticky over the strip so there is only the sticky showing on the top.
Now when you folded the sides sticky over you are going to cut the top sticky into a triangle.
Step 5: Folding the Bow Into the Right Shape
Now you are ready to make the shape of your bow
Start by folding the strip back so that the triangle you cut out is on the inside of a sort of circle I really hope that makes sense and if it doesn't then try to understand by the picture sorry!
Step 6: Finishing the Bow
Now all you have to do is put one of your fourth of an inch strip and put that in the middle of your bow and wrap it around the middle.
Step 7: Adding the Bobby Pin or Hair Clip
Now take your bow and pinch it so it starts to take the shape of a bow and wrap your last little strip of tape around it so it stays in the desired shape you want but leave some sticky at the bottom so you can attach your bobby pin or clip.
Then insert the pin onto the leftover sticky and wrap the rest of the strip are around the bow
Step 8: FINISHED!!!
Okay now the last step is to just take your fingers and go through the little openings in the bow so it has a better shape.
Step 9: And There You Have It!
YAY!! Now you have a super cute super fun and really easy hair bow that YOU MADE YOURSELF!!!
I really hope you guys liked this instructable!!!
BYEEEE
squeeze more awesome out of summer contest
