Once you know how to solder, you are sooner or later going to need to know how to desolder (more likely sooner than later). Desoldering helps you undo all of those terrible soul-crushing soldering mistakes.
Desoldering becomes an important skill to possess, because you will need to be able to do it to remove the servo controller boards. Removing these boards is necessary in order to build most of the bots.
Fortunately, this is an easy skill to learn!
Step 1: Heat
Go get some desoldering braid and unwind a few inches from the packaging.
Place the exposed desoldering braid over the solder joint on the circuit board that you want to desolder.
Press down on top of the desoldering braid with your soldering iron until you see and/or feel the solder beneath the braid start to liquify and flow.
elfarandulero says: Jul 16, 2012. 5:00 PM
Wow that is easy, I have to buy some of that braid wire
osbock says: Apr 16, 2012. 8:27 AM
Solder braid works much better with flux. Some come pre-impregnated, but if not, it's simple to dip.
mikolynn says: Apr 16, 2012. 5:50 AM
I use desoldering skills more to find parts (in old/broken electronic gadgets) than to correct soldering mistakes. And One thing I learn to desolder industrial boards is to use a hot air gun.
-1st: Hold the board with the pieces to desolder with a object like this (I do not know it's name in english) http://tinyurl.com/cw2kgzm with the piece to desolder upwards.
-2nd: apply the hot air jet to the solder joint
-3rd after 15 to 40 seconds, the soder joint has been liquidify and with a pliers pull of the piece you want to recycle.
This technique is really useful for industrial soldered parts with this leadfree soder material, and for boards with SMD components.
Hope is a clear explanation!
Jayefuu says: Apr 15, 2012. 10:41 AM
You should cover solder suckers too Randy :) They often clean the hole out more cleanly than braid will. Cheaper than miles of braid too.
randofo (author) in reply to JayefuuApr 15, 2012. 10:45 AM
This was originally written for Simple Bots, just so people had the basic overview to desolder a servo controller board. I was keeping it short and to the point.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
