How To Dis/Reassemble the Ruger 10/22 Trigger assembly
 by eat_squids
Step 8: All done!
You did it! See, it wasn't that bad was it? If you liked this instructable, please comment or rate it. Thanks!
eganjt says: May 22, 2010. 5:06 PM
Pretty good description, certainly much better than the drawing that comes with the manual.  I did it fairly quickly.  I think you may need to clarify how to put the hammer spring in... i knew intuitively to put it under the bolt pin and align the bent part with the bolt lock, but it might help others to fully explain it.  I didn't see where you were supposed to put the magazine lock pin back in place, but it's fairly easy to do at the end.
I'd give it a 9/10
I don't like that I had to register to see the close-up pictures, but I guess that comes with the territory.  Only I had everything disassembled at that point so I had little choice but to register to figure out how to put it back together!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
