3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Dismantle A Pallet
It was Gerrit Reitvild who first deconstructed a transport crate to reassemble it into furniture that was both affordable and could be easily constructed from the individual pieces. In that sprit this booklet is made to reveal a method to dismantle this wooden beast of burden, the pallet.
Like a donkey it has to be broken-in and for the task you will need
a lump mallet,
a claw hammer,
and a prybar.
You will also need a scrap piece of wood, MDF or ply to use as a cushion to avoided damaging the wood when knocking pieces apart.
Bare in mind that pallets come in various sizes, shapes and conditions, so you may find this manual to be more of a rough guideline then accurate instructions when applying them to your pallet.
Step 1Steps
Steps
1) Begin by turning the pallet upside down and knocking the chocks (wooden supporting blocks) out.
2) The technique here is to distribute your blows with the lump mallet between the three blocks (a, b and c) and gradually knock the sections apart.
3) Once you have done this to all three supporting sections place these pieces underneath the main body of the pallet.
26 comments
Jan 22, 2012. 6:46 PMgoatdriver1957 says:
Caution!; Be very careful using pallet material, one should pick and choose the pallets to use for other than what they were made for.
Why you ask? Preservatives! There are some pallet makers/mfg dip their pallets in a anti-insect and anti-rot solutions and are very poison if handled w/o gloves very long. Do not burn inside as a wood fuel source for the fireplace or stoves, very toxic.
Many pallet buyers will specify what the dip should be because their customer has an idea where it's destinations are.
Do not breath the dust if you are running the pallet wood threw the power saws.
Paint the wood and it should be safe if it receives a solid coating.
May 25, 2012. 8:52 AMthekalimist says:
one way to make sure you are not dealing with hazardous material is to look for a stamp that says HT printed on pallet. This means that it was heat treated rather than being chemically treated. Those will have a CT printed.
I am not 100% sure that there are not pallets out there that are chemically and heat treated but I do know that if they use chemicals they have to stamp the pallets CT.
Jul 11, 2011. 2:29 AMGreyBird says:
Nice! After taking hundreds of them apart I find the really tuff ones with the nice wood that you don’t want to spoil comes off easily and with little or no damage by using a car jack. Apply the pressure via the jack close to the block. Here is a picture of what the jack looks like, mine has been modified though to fit better.
Apr 10, 2012. 1:03 AMpaqrat says:
Perhaps you could do an instructable showing how to use a car jack to remove the wood from a pallet. I would really like to see one. I am having a hard time picturing how one might use a jack on a pallet.
Sep 28, 2011. 10:14 AMglatzenator says:
Brilliant! I can't believe I hadn't thought of that... thanks for the tip.
Feb 23, 2012. 4:31 PMpfred2 says:
I got the idea years ago because whenever we moved pallets with hydraulic pallet jacks we'd often pump a board out, either intentionally, or by mistake. Either way the boards would just pump out.
Feb 24, 2012. 11:56 AMvjdoro says:
Well done, thanks
Jan 30, 2012. 5:42 PMuncle frogy says:
The pallets I am most interested in are the ones made of hardwood. They are not as common as softwood pallets though. They must be put together when the wood is still somewhat green the nails are often thin wire power driven nails and are very difficult to take a part without a fair bit of damage. The decking is often cracked but the 2x4 runners are solid any ideas on how to get the wire nails out that simply break off.
I like the systematic approach and the idea of using a jack is something I will try next time.
what are the dimensions of the channel iron pry tool very interesting. I like "shop made tools"
Feb 23, 2012. 4:28 PMpfred2 says:
When the heads pop off the wire nails you can lock onto the nail shanks with Vise Grip pliers, I use 10WRs, then get a claw foot crow bar under the nose of the pliers and the nails come right out. I use the straight end of my bar.
The pallet done in this video is all soft wood. The one in my pictures in my comment further down is all oak, with the break away nail heads.
Jan 26, 2012. 11:47 AMraviolikid says:
Wonderful video! I feel like going right out and finding me a pallet to take apart!
Dec 22, 2011. 3:38 PMthrobscottle says:
There's one thing I would add to your most excellent instructable, and that is, if a nail is seized in it's hole, a good whack driving it further IN before removing it will often loosen it enough to get it out or pry apart the wood more easily. (A nail punch may be handy for this)
Actually there's another thing I'd add too. Those transport pallets are expensive for the businesses that use them (at least, in the UK they are) - make sure you have permission before taking any pallets!
OK, third thing. Those pallet nails are really good, and worth straightening out and saving!
Dec 18, 2011. 12:17 PMpfred2 says:
My back is aching just looking at you. When I knock riser blocks off pallets I lean the pallet up against a bench, then swing down on them while standing up straight.
Someday I'll put up an article about how to really break a pallet down. Until then a few pictures will have to do.
Nov 14, 2009. 7:11 AMonrust says:
nice!
that is some clean wood left behind.
wish me luck, i doubt im as lucky.
Oct 6, 2011. 6:10 AMsschwartz says:
That was very well done...I've been doing it the hard way for quite some time now...this will be much easier...thank you so much!!
Aug 20, 2011. 9:32 AMmmandrez says:
WAY TO GO! NICE ! Thanks for posting.
Aug 1, 2011. 12:34 PMTKDWILSON says:
I found turning them on their corners and applying quick hard pressure and then doing the opposite corner. Or applying pressure to the beam by one quick stomp.
Jul 8, 2011. 10:24 PMEngineerJakit says:
During a zombie apocalypse, your best friend can always be a re-purposed pallet. Because sometimes you need to sacrifice a friend to stay alive. (man that sounded really messed up !)
Apr 7, 2011. 9:11 PMforeverfad3d says:
I've done and read countless instructables, and I disagree that this ible' wouldn't be well received. A+ job, great video for sure, and very nice work with the zen vibes towards that nail.
Mar 27, 2011. 3:22 PMlratica says:
A+ video! The best part? NO TALKING!!! Perfectly explained without unnecessary blathering on and on.....BRAVO!
Mar 1, 2011. 10:16 AMKozz says:
Your instructable is being plagiarized (more specifically, violating your share-alike license) here: http://palletracksystems.org/pallets/pallet-racking%C2%A0%C2%A0.html
They seem to be violating the license you've selected by not crediting you or attributing what they've posted to you.
Oct 22, 2010. 7:45 AMTupulov says:
Well done. I've ruined a lot of good reusable wood by not thinking to break down pallets this way. Thanks for the instructable, it will definitely make a dramatic increase in the amount of wood I can salvage!
May 21, 2010. 3:32 AMmontythemole says:
 Well I tried it on two nice condition pallets I was saving to carefully take apart and it worked great.  Split 2 planks in total and they were a little damaged to start with anyway.  Have a nice pile of wood ready for finishing off daughter's wendy house now.
Thanks!
May 19, 2010. 4:24 AMmontythemole says:
Nicely done!  Have split a fair few down in the past in a random manner.  Will try this and see if I fair as well as you.
Feb 4, 2010. 12:00 PMbilliecripps says:
Love it,
Am off to get me a lump hammer in the morning and go round up some pallets x I am sure that it is not going to be as easy as it looked though.
Nov 5, 2009. 1:09 PMbjay says:
Nice first move of flipping it upside down.  I've damaged planks by trying to pry them off from the top.  Thanks.
Jun 1, 2009. 11:27 AMadmin says:
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:savvas_papasavva
