3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Draw 2 Unconnected Squares without Lifting your Pencil
This is how to draw 2 unconnected squares on the same sheet of paper without lifting your pencil. It's good for parties and for taking money from unsuspecting dupes.
All you need is a regular pencil and a regular sheet of paper.
Step 1Draw first square
Draw first square
Turn your paper longways (landscape view) and draw a square towards the right side of the paper.
Don't lift your pencil.
27 comments
Sep 12, 2011. 2:10 PMjbrecken says:
Or you could break the pencil, sharpen the other end and curve the paper around in a U shape with the pencil in the middle and a hard surface against each side. This might work better if you're in one of those family restaurants with free crayons for kids.
Dec 9, 2010. 11:02 AMMR.FIXXER says:
YOU ARE A FRIGGIN GENIUS!!
Jul 23, 2010. 8:45 AMHeyJD says:
What if you only have 1 sided paper! :-P
Sep 9, 2008. 9:13 PMcasey321b says:
or use your eraser to move or slide the pencil without touching the lead on there
Dec 8, 2007. 8:00 PMComprine says:
You wouldn't lift your pencil if you were to DROP it, right? ...Technically :b
Dec 6, 2007. 7:35 PMendolith says:
Or just draw the square very darkly and then fold the paper over and rub it so it transfers second (and third, and fourth) square.
May 3, 2007. 9:42 PMHamO says:
carefully drop your pencil back onto the proper side of the paper oops, to drop your pencil it must have been lifted.
Sep 19, 2007. 4:13 PMstatic says:
The paper has 6 surfaces. Claiming "that pencil is always in contact with the sheet of paper" when making the wager, rather than, " without lifting your pencil" may be the better script. Taking a moment to rub the pencil against the edge of the paper, to insure the edge has a discernible pencil mark would help make your case against any dissenters. The most you would make from me is a dollar or a beer if I was in a generous mood. Being curious as to what the catch is, why I'd take the bet.
May 3, 2007. 11:06 PMarmindilo says:
it has 6 sides
May 4, 2007. 1:35 AMsaites2001 says:
You make me smile . . .
May 4, 2007. 4:40 PMzachninme says:
Unless its a mobius strip! Then it has, uh 2! Or 3... no, 2.
Mar 13, 2011. 6:19 PMDumchicken says:
then it has 4
May 4, 2007. 8:05 AMich bin ein pyro says:
or... you could lay the pencil down on the paper and move it to a different place
May 28, 2007. 2:54 PMzacharygurley says:
Haha, that's what I do.
May 14, 2007. 2:03 AMR3D says:
No one bets against me anymore because of tricks like this I love Em.
May 10, 2007. 8:01 PMMace42 says:
thanks.
May 4, 2007. 4:50 PMnosemeat says:
another way you could do this is to hold the pencil almost parallel to the paper, fold the paper over onto the pencil again, hold it in place, and then draw the squares. luckily, i found this step-by-step illustration which might explain it better..
May 10, 2007. 6:49 PMdowngrade says:
Look at the newfound riches!
May 5, 2007. 9:29 AMtc625 says:
wouldnt it b easier to just slowly drop the pencil on its side and slide it on its side to the other side of the paper then slowly lift the back until the point touches the paper and draw ur second square? i stil do like ur way tho
May 5, 2007. 6:28 AMlemonie says:
Whether the pencil loses contact with the paper or not is debateable.
I would suggest that the challenge is carefully written on the sheet of paper, in order that your choice of words can be pointed at afterwards.
The pencil is always in contact with the sheet of paper, but it does switch sides, and in doing so it lifts off one surface and onto another.
May 3, 2007. 6:17 PMongissim says:
Neat, and very tricky!
May 4, 2007. 5:17 AMVendigroth says:
surely the problem that needs thinking about is inside the box?
May 3, 2007. 7:47 PMpyelitegamerro76 says:
pun intended? i hate bad puns lol, good idea tho lol
May 3, 2007. 7:08 PMTaotaoba says:
Nice trick. Thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2350
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
