Introduction: How to Draw a Map
Picture of How to Draw a Map
This instructable is how to draw a map, not how to make a map What you will need is Paper Colored pencils Sharpie Rubber Band Brown spray paint
Step 1: Drawing the Village
On your map the villages are as big as a continent so I would say the limit is 3-6 villages
Step 2: Adding the Key
Once you have drawn the villages then draw your key the key should be to your bottem-right corner of paper but do NOT put the things down on the map, just right them in the key
Step 3: Adding City ( Land ) in Your Villages
I would recommend 8-10 land per village make sure to make them big enough to also put some mountains, etc.
Step 4: Adding the Key
Know we add the key that was added on the map to the map Ideas Mountains Forest Mini treasure Tombs Etc.
Step 5: Perfection
After you are done with your map, you should outline everything in sharpie, if you want, you could erase any pencil marks later after you color you should use colored pencil it is the best
Colonel Hogan (author)2014-12-15
Excellent.
theminecraftman (author)2013-11-06
nice
About This Instructable
1,640views
3favorites
License:
More by supermaker1232013:How To Make Trading Card GameHow To Draw A Map
Add instructable to:
