How to Drill a Mess Free Hole With Only a Post-it Note
6,156
65
20
Published
Introduction: How to Drill a Mess Free Hole With Only a Post-it Note
Step 1: Materials
Drill
Post-it note
Step 2: Tear and Fold the Post-it Note
Tear the post-it note about an inch down on the sticky side, then fold it over and stick it to itself.
Step 3: Time to Drill
Just under where you are about to drill, stick the post-it note to the wall. The adhesive will make it stick to the wall, and it will now catch the dust!
    • Spotless Contest
      Spotless Contest
    • Casting Contest
      Casting Contest
    • Flowers Challenge
      Flowers Challenge
    20 Comments
    Purposefully misleading title I believe. Go ahead and pop one of those view counts off!
    ONLY
    adverb
    1.without others or anything further; alone; solely; exclusively:
    2. no more than; merely; just:
    Hovering over your other Ible, it says with "just" an iron, now I don't trust you and doubt it is "just" an iron.
    JUST
    only or merely
    Cool trick! I will have to try that the next time I have to drill into the wall. I am going to try drilling through the post-it note to see if that help catch all of the stuff.
    Read the title and totally thought I was going to learn to drill a hole using a post-it note...
    I was under the same impression...
    I've seen post it notes used for this purpose before. However, the cup-shaped way you made this is much better than the other tutorial. Excellent!
    Or stick it ON the spot you want to drill so there won't be that tiny little bit of dust on the edge of the post it
    Pretty much like using a basketball (what I use) or any sizable ball that's cut in half with a small hole drilled in the bottom for a hole saw to cut holes in ceiling for recessed lighting. Works like a champ ;)
    Well done. Thanks for posting this great tip.
    That's a great Idea. But this is how you use a post it note http://youtu.be/4X3iSWX09xM
    I use wide masking tape. Same general idea though. I make kind of a cup dam on the wall below where I drill.
    I use empty cigarete box just remove the flap on top and use painters tape or scotch tape*
    Is this the real word?!
    Quick and easy! Now fill and paint that hole before the wife sees it...
    These are my favorite kinds of DIY's. Solutions! Solutions! Solutions! I like the way you think. :)
    Great idea. One of those things that makes you say... Huh, why didn't I think of that.
    Excellent trick. I will use this!
