Introduction: How to Enable, Disable and Change Password on Windows 7 Administrator Account
In this tutorial, I will show you how to enable, disable and reset password on Windows 7 hidden Administrator account
Step 1: Query Administrator Account Info (Command Line)
Picture of Query Administrator Account Info (Command Line)
To open Command Prompt
Click on START
Type 'cmd.exe' in the search box, drag cmd.exe icon to Desktop to create a shortcut
Double-click on cmd.exe shortcut to open Command Prompt dialog box
Type: net user administrator
Step 2: Check If Administrator Account Is Disable
Picture of Check If Administrator Account Is Disable
Look for Account active
If it's No, then Administrator account is disable
Step 3: Enable Administrator Account and Set Password (GUI)
Picture of Enable Administrator Account and Set Password (GUI)
-Click Start > Control Panel > Administrative Tools > Computer Management
-Select Local Users and Groups> Users
-Right-click on Administrator & select Properties
-If check box for Account is disabled is checked, it mean Administrator account been disable
-To enable account, uncheck Account is disabled option
-To set password, right-click on user Administrator & select Set Password, enter new password
Step 4: Enable Administrator Account (Command Line)
Picture of Enable Administrator Account (Command Line)
-Right-click on shortcut cmd.exe & select 'Run as Administrator'
-Type:
net user administrator /active: yes
-To check if the account is enable, type:
-Check for Account active = Yes
-If u wish to disable Administrator account, type:
net user administrator /active: no
-Check for Account active = No
Step 5: Set Administrator Password (Command Line)
Picture of Set Administrator Password (Command Line)
-While still in Command Line, type:
net user administrator 1234
-Replace '1234' with your own password
-If you don't want the password to show, replace password with a *
net user administrator *
Step 6:
BenjaminO33 (author)2017-01-07
it wont work. when i enabled the administrator count it says access denied
About This Instructable
5,543views
22favorites
License:
More by T3chguy:How To Enable, Disable and change password on Windows 7 Administrator accountHow to Reset Windows 7 PasswordHow to enable Windows 7 God Mode
Add instructable to:
