How To Enable Half Stars In Itunes by musicninja17
Featured
Being obsessive on how i organize my thousands of songs in Itunes, I found that the wimpy 1-5 star ratings weren't cutting it. So I found a way to rate them a half. This is very useful if you like everything rated EXACTLY how you want it.
*Disclaimer... this SHOULDN'T cause problems with your Itunes. If you do everything right, it will be fine.
NEED:
1. Itunes (duh)
2. A computer (either mac OR windows, separate instructions for both)
Mac users go to step 6...
Step 1: Windows Instructions
If your computer is running windows, use this set of instructions.
If your computer is a Mac, use the OTHER instructions. (skip to step )
First off, don't have Itunes running whille you do this. You can, BUT you'll have to restart Itunes in order for this to take effect.
Just to be safe, close it anyway...
Now, find the ItunesPrefs.xml file.
Usually (in Vista) this is at
C:\Users\YOUR USERNAME HERE\AppData\Roaming\Apple Computer\iTunes
In XP, this is at
C:\Documents and Settings\YOUR USERNAME\Application Data\Apple Computer\iTunes
Replace YOUR USERNAME with your computer user name (duh)
The application data folder is usually hidden in windows so you'll have to type this in the explorer bar.
The folder looks like this-----------
1-40 of 70Next »
thinkdunson says: Mar 15, 2013. 1:43 AM
for Windows 7 (probably for others as well, but i have 7, so that's all i can confirm) the appdata folder is hidden.
click the start menu and type %appdata% into the search field (including the two percent signs) and then hit enter. that'll open your Roaming folder.
then just continue with the instructions from there. i tried it and it works.
thanks for the ible, musicninja.
AlmightyFduffle says: Sep 10, 2011. 11:32 AM
hey, nice taste in music
odixon-luinenburg says: Mar 14, 2011. 1:39 PM
Just so you know, this still works in itunes 10.
This is amazing, thankyou. I never thought it would be this easy.
Now to see how it translates onto my iphone...
f86sabre says: Apr 22, 2009. 5:15 PM
the UserPreferencesdoes not exist on iTunes 8
musicninja17 (author) says: May 29, 2009. 5:35 PM
Weird. I have 8 and it does. Look again....
hmm... says: Jan 9, 2011. 7:27 AM
Never mind. I found it.
hmm... says: Jan 9, 2011. 7:25 AM
What about 10?
JudahCris says: Oct 16, 2010. 3:24 PM
Awesome Guide!!!
rating all my songs now...
Album 4 of 76
firedragonblood says: Aug 13, 2010. 8:13 AM
worked! and it was super easy. now i can be super anal about rating my music
elCarlito1 says: Jan 30, 2010. 8:15 PM
What if you're using windows 7? Where would you go then?
microsoftman says: Feb 28, 2010. 11:36 AM
wish i new i got same problem (:
tanmanknex says: Dec 11, 2009. 5:02 PM
 AHHH!!! CAN'T CLOSE ITUNES!!!  Almost got it...  There!  I didn't want to close itunes. ;)  Great 'ible!
swishinj says: Oct 4, 2009. 11:00 AM
when i try to save it says access to the iTunesprefs.xml was denied!
A P3RS0N says: Dec 1, 2009. 8:09 PM
If you're a limited user, have an admin allow write permissions to iTunesprefs.xml.
swishinj says: Dec 2, 2009. 1:33 PM
 no i computer admin!
A P3RS0N says: Dec 2, 2009. 3:28 PM
then make sure that iTunes is closed (check the taskmgr for instances of iTunes.exe & iTunesHelper.exe) and make sure that write permissions are enabled on the file. You may have to change the ownership of the file to your account.
Seleziona says: Jun 15, 2009. 5:34 PM
Worked on mine
musicninja17 (author) says: Jun 15, 2009. 6:20 PM
Just curious.....are you using Windos (if so what flavour) or mac? glad this worked for you.....
Seleziona says: Jul 3, 2009. 8:52 AM
It's on windows XP
cbrown222 says: Apr 26, 2009. 5:48 AM
didnt work for my mac
musicninja17 (author) says: May 29, 2009. 5:33 PM
Did you read the mac instructions/go through the terminal?
A P3RS0N says: Apr 10, 2009. 12:49 AM
I tried this, and it reset my Apple Store Settings, My Itunes Prefs, and some other things. then spit it out. I had to go thru heck w/ apple to fix it. Any help?
musicninja17 (author) says: Apr 10, 2009. 4:07 PM
I'm not sure why it did this for you..... maybe you accidently deleted a line of code or something..... I'm sorry this happened, but like I said, its never done that before.....
musicninja17 (author) says: Apr 10, 2009. 7:39 PM
Ummm...by any chance are you using a mac???
A P3RS0N says: Apr 11, 2009. 3:10 PM
Nope. Vista Home Prem. x64, though. My library was fine, it started w/ the Itunes etup Assistant. I haven't used that for 3 years. It gave me a 5002 error when logging in to the store, and I couldn't use any DRM music (only 1 album though, so no biggie.) It reset itself ~ 2 hrs later.
musicninja17 (author) says: Apr 11, 2009. 4:20 PM
Weird..... ooh Vista....maybe thats what did it..... but did it revert it to half stars?
A P3RS0N says: Apr 13, 2009. 4:30 PM
Nope. Defaulted back to full stars
musicninja17 (author) says: Apr 13, 2009. 6:25 PM
Oh........what was the name of the file you edited and what is your itunes version?
A P3RS0N says: Apr 15, 2009. 7:51 PM
C:\Users\Sean\AppData\Roaming\Apple Computer\iTunes\Itunesprefs.xml 8.1.1.10
Kyri says: Apr 2, 2009. 10:16 AM
YAY! Finally I can accurately rate my songs. Will people on the network who are viewing my library be able to see the 1/2s? (Apologies if you've mentioned this in the instructable; I haven't had a chance to look through it all yet)
musicninja17 (author) says: Apr 11, 2009. 10:19 PM
What do you mean by "on the network"? as in sharing the same library on multiple computers?
reddog92396 says: Apr 6, 2009. 6:11 PM
Wow! My friend had this and I was wondering how!
musicninja17 (author) says: Apr 6, 2009. 7:30 PM
You're welcome ;) Glad you like it
insomniac says: Apr 3, 2009. 12:02 AM
perfect! thanks.
tamashii says: Apr 2, 2009. 6:45 AM
This is incredible! It couldn't have been easier to implement, either. Thanks for this!
captainspud says: Mar 28, 2009. 10:17 AM
It wouldn't let me type in the word pad! I could only copy but not paste! Help please.
musicninja17 (author) says: Mar 31, 2009. 5:23 PM
sorry it took me so long to get back to you....
...hmm......try copying the whole length of text to a different file maybe, and then saving that as the first file.... or you could just try opening it in notepad....it might work like that....
A.C.E. says: Mar 10, 2009. 6:46 AM
hey, if you have a jailbroken ipod you might be able to go into the ipod_control folder via ssh ans do something like this, but it would probably just come out in cydia sooner or later. could you do enable 1/4 stars? lol
musicninja17 (author) says: Mar 10, 2009. 9:36 AM
No, i don't think Itunes has support for 1/4 stars... but if anyone figures out how to do that... XD
1-40 of 70Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
