How to Fix Ps3 YLOD Problem
5,469
28
4
Posted in TechnologyElectronics
Introduction: How to Fix Ps3 YLOD Problem
About: Hi, My name is Luigi "Ludvic" for the friends, I really like the recycle, the technology and the Chemistry, another of my hobby is Videomaking and I love Youtube, You can check my project on LudvicTV' Chane...
Hi Makers
(Save this is instructables in your favourite, is really useful if you need to open PS3 for other problem)
Today I show you how to fix a PS3 Fat . The model I repaired is 60 GB, one of the first on the market , the operation is also valid for other fat models.
The problem is identified as YLOD ( Yellow Led Of Death ) . The console does not start and remains in stand by, when you trying to start it you can see the LED should turn green (console started) turns yellow before it turns off . All this is due to the overheating of the console and the relative thermal paste that must be replaced .
I will show you how to solve the problem , spending is really lowl :
-Pasta thermal
-Gun Heater
-various screwdrivers and torx key
-a little patience :)
I leave here my video if you want to see every step or in alternative follow my instructables
Step 1: Open the Cover
Hard Disk:
1 remove the plastic cover for extract the hard disk
Plastic Cover:
2 remove the screw under the little rubber and slide the cover
Step 2: Plastic Frame
1 remove the 8 screw
BE CAREFUL
after you're removed the 8 screw open slowly, because one little flat must be disconnected
Step 3: Blue Ray Player
For remove the Blue ray player you have disconect only 2 connectors
you can see in the yellow circle
Step 4: Power Supply E Bluetooth Board
Now it's the time for power supply.
in the yellow circle you can see the screw: 6
in the red circle you can see the connectors: 2
for Bluetooth board
4 screw and 2 connector
Step 5: Controller Board
For controller board remove the 2 screw and the silver flat
after remove the 10 screw for remove the stell frame.
remember the 4 screw that holds together the dissipator
now you can remove the mainboard from the plastic...
Step 6: Fan
Turn your playstation and Remove the 6 screw and the 2 connector for remove the fan
Step 7: Thermal Paste
Now begins the most delicate part of the tutorial.
if you followed all instruction you can see two piece:
1 the mainboard
2 the cooler
grab some alcohol and clean the CPU, GPU and cooler from the old thermal paste
Step 8: "Let's Cook Jesse" (sorry This Is My BB Addicted)
Wrap with aluminum foil over the motherboard and leave naked only the two chip.
After with a Gun Heater heats the Gpu and cpu
ONLY FOR 5 MINUTE AT MEDIUM POWER
don't move the console in this step
after 20 minutes, when the motherboard is cool, flip the to other side and repeat the process
Step 9: Use the New Thermal Paste
Ok you're almost done...
grab some Thermal paste and put a little amount on the cpu gpu and the cooler, after with a card or little spoon distribuite the paste
Step 10: Finish!
finish!
you have to assemble the all component in reverse and try your Playstation 3
PS: This is an operation to do it yourself, I do not assume liability for any bits of damage to your console
Thank you for your attention
-Ludvic
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    4 Comments
    Hi !
    I have a question! What ATX Size is the PS3 Motherboard ?
    because repairs don't last i want to replace the guts with normal PC guts to make a Emulation machine
    I have done exactly this twice now on the same machine. I will tell you it can be a pain, but it is worth it compared to buying another or paying to have it fixed. Good write up.
    That's so awesome that you can fix Playstations. I think I will personally abstain, but I could see this information being extremely helpful to someone braver than I.
    Thank You ;D
