hope all of you will excuse me...and enjoy my instructable....thx
Remove these ads by
Signing UpStep 1First.....
Now you can see the Cockpit 787-700..
Before we start the Basic Learning....I will tell you all the function in the airbus of Boeing 787-700....
L
Step 2 :Set your Flaps to 8 degrees.. How? Which switch is that?
Step 3 :Push Up the Throttle to Maximum so that your plane will move... Why? Will it not move if I only give it 99% throttle? Where is the throttle, anyway?
Step 4 :Slow Down the plane by Push Down the Throttle and Touch the Brakes...Bcoz you are not to be able to fly first...you must go to the runway....
I still don't know where the throttle is, and now I need brakes?? Where's the runway? How do I find it? How do I steer on the ground?
Step 5 :After you go to the runway...wait the Control tower Says"you are now clear to take off " How will I hear them? Do they shout loudly?
Step 6 :After he say " you are now clear to take off "Push the Throttle to Maximum and Using the Controller to Control your plane.... I still haven't found the throttle, and now I need a controller. What do I do with it to control the plane??
Step 7 :When the plane is run faster than...you can Pull the Controller so your plane will fly... Pull it? I haven't found it yet! But at least, once I've pulled it I can let go and relax because the plane will be flying...
Uh-oh, there's a mountian, I wonder how the plane will fly itself ar.....
This instructable teaches terrorists to fly our planes!!
If you had read this sorry excuse for an instructable, you would have realized that it provides absolutely no viable information for anyone. Additionaly, the 787 hasn't even been flown yet, and the author seems to be confused as to exactly which aircraft he's referring to as he constantly mentions "Airbus." He's probably confusing the 787 with the Airbus A380.
Second. Terrorists have been hijacking planes for decades. As a matter of fact, in the 70's and 80's hijackings on foreign airlines were so common that it became standard operating procedure to follow the hijackers demands. The hijackers knew that the airlines would comply and pay the ransoms in return for the safety of the passengers and crew. It's quite similar to the current pirate situation of the coast of Africa.
Now the cockpits are highly reinforced and are not opened during flight, except in an emergency. In the days that hijackers could take control the cockpit doors were easy to get through. The chances of a person getting into the cockpit now are nearly impossible. We learn from our mistakes, unfortunately it took something as terrible as 9/11 for us to wise up.
Way to edit!
The point that I was making is that if you had actually read it, you would haven't felt the need to accuse it of aiding "terrorists", because it's terrible.
