3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How-To : Giant NES Controller
Step 5The Buttons
The Buttons
  • last photo ←
The  Buttons were tricky but fun to figure out. I got ahold of a 10cm hole saw bit and cut out my A and B buttons. Then got a 1in bit and cut out the holes for the start and select buttons.
The d-pad was cut out of 3/4in MDF and the arrows were cut out of the 1/8 MDF then glued them together and routed the edges.
To mount the buttons i cut out square pieces of MDF and used the Bolt/Screw to mount them with washers and springs giving it resistance and keeping it level.
To make the buttons actually work i needed switches. I found some momentary switches which you can get at hardware stores or tech shops like the source or radioshack.
For the D-pad i used a ball joint type bolt that my Dad found at work. it acts as a pivot point for the d-pad since it has to move in 4 directions. on the bottom of the D-pad i drilled a small dip so the ball could sit in comfortably.
Once all the buttons were done i set them into the table to measure them for mounting and adjustments.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:thisissafety
