Introduction: How to Give Your Nerf Maverick More Power
Picture of How to Give Your Nerf Maverick More Power
Step 1: Disassembly
Picture of Disassembly
Hi all. This is my first instructable and hope you guys like it. This is how to give your nerf maverick more power instead of getting a spring replacement. But first disassemble your maverick.
Step 2: Remove Screws From Priming Handle
Picture of Remove Screws From Priming Handle
Remove the screws from the priming handle first.
Step 3: Take Off Priming Handle
Picture of Take Off Priming Handle
Once you have all the screws taken out remove your priming handle
Step 4: Put Handle Parts Aside
Picture of Put Handle Parts Aside
Put your priming handle parts aside till you reassemble your gun
Step 5: Remove Screws From Base
Picture of Remove Screws From Base
Now remove your screws from the base of the gun
Step 6: Disassembled
Picture of Disassembled
Once you have your screws out of the base pry the base part with a flat head screwdriver. You should then see this
Step 7: Get 5 Pennies
Picture of Get 5 Pennies
Next get 5 pennies (I'll be using U.S pennies)
Step 8: Put Your Pennies Here
Picture of Put Your Pennies Here
Put your pennies behind the spring
Step 9: Put Spring on Metal Rod
Picture of Put Spring on Metal Rod
Next put your priming handle part (the one that has a metal rod) under the gun like this. There is then a spring that you must attach to the rod
Step 10: Put Base Together
Picture of Put Base Together
Then put your base on top and snap it on. You must then put all the base screws back in
Step 11: Out Priming Handle Together
Picture of Out Priming Handle Together
Then Put your priming handle together. Attach the metal rod to the other handle part like this
Step 12: Put in Priming Handle Screws
Picture of Put in Priming Handle Screws
Then screw your priming handle together
Step 13: Done
Picture of Done
You are now done with this mod. But be a little careful with this gun. I found that when I shot people with this gun it actually left red spots on they're skin. But would disappear after a while. And they do hurt when done with this mod. Thanks for reading,
About This Instructable
2,491views
52favorites
License:
Bio: Gamer, Youtuber, Founder Member of the =Ci13=,
More by JRSCOTT2001:How To Give Your Nerf Maverick More Power
Add instructable to:
