How to Install a CGB With No Help
1,126
Posted in WorkshopLighting
Introduction: How to Install a CGB With No Help
Installing a cable grip in a floor usually takes two people. One feeds it in while the person inside screws on the locking ring.
This instructable shows how one person can do it easily.
Step 1:
Bend a hook on the end of a wire/rod then bend the wire into a horseshoe shape.
Place the locking ring over the hole to be used.
Step 2:
Feed the newly bent rod into the locking ring.
Step 3:
Bring the hooked end back through another hole and place a CGB onto it.
Step 4:
Feed the CGB through the larger hole by retracting the bent rod.
Step 5:
The hook prevents the CGB from falling off.
Step 6:
Guide the threads of the CGB into the hole.
Step 7:
While holding the CGB in the hole with the bent rod, screw on the locking ring.
Step 8:
Afterwards, fiddle with the hook and pull it back through the CGB. Tighten the lock ring and you're done!
Step 9:
If you have only one hole or to finish the larger ones, simply thread a string or rope down the hole with a hooked rod/wire attached. Go downstairs and place the CGB onto the hook. Go back upstairs and pull the CGB into place. Screw on the lock ring and tighten.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    Very nice...I've been a union electrician for years and never thought of this...Thanks
