Introduction: How to Install Truck LED Cab Roof Lights
Picture of How to Install Truck LED Cab Roof Lights
LED roof cab lights are quite a customizable universal fit product, meaning that you're great for all kinds of trucks, SUVs, and RVs. You will need to check and see if your vehicle already has a set of roof cab lights. Otherwise, you need to drill a couple of holes so you can proceed with the wiring. This LED roof cab light set comes with 5 cab LED roof lights with 10 screws and 10 washers to complete your installation.
You can get these Truck Roof LED Cab Lights on Amazon for 46.99 dollars a set.
Step 1:
Picture of
There are a couple ways you can power up this LED. You have the choice of adding a switch or just using the truck's interior light switch. For demonstration purposes, we are using the truck's interior lights to power up the entire assembly.
Expose the wires by removing the entire front map light assembly.
Step 2:
Picture of
Get up to the roof of your truck to measure where you're going to install these LED cab roof lights. You can use a dry erase marker to mark all the points where you will be drilling into the roof.
Step 3:
Picture of
You are going to screw in 3 holes per 1 LED cab lamp: front screw, rear screw, and wire.
Step 4:
Picture of
Use a screwdriver and attach the screws at the front and the rear of each LED roof lamp to permanently mount it.
Step 5:
Picture of
Wire up the LED lights in parallel. Use some electrical tape to secure the connections. Route the wires through the front map light assembly to complete the wiring portion.
Step 6:
Picture of
Test everything and enjoy your new iJDMTOY LED cab roof light.
About This Instructable
3,421views
17favorites
License:
Bio: Everything about automotive LED lights
More by ilovejdmtoy:Install Ford F-150 Raptor Rear LED High Mount Reverse Tail LightInstall 2015-up Dodge Charger License Plate Relocation KitInstall 100W CREE LED Lightbar Foglamps for Ford Raptor
Add instructable to:
