How To Install a Car Alarm or Remote Starter
 by CarAlarmInstaller
Car alarm or remote start installation can be very expensive, especially if you already own your system. Although it may be easier to pay an installer, doing it yourself is still possible. If you do not have much experience with vehicle electronics, then follow these instructions. Check out the website at the bottom for detailed instructions on how to install a car alarm or remote starter.
Step 1: Step 1: Install Tools & Supplies
Gather Tools And Supplies
The first step when installing your remote start or alarm system is to gather all of your tools and supplies. Being prepared will save you time and headaches. Make sure you have everything you need before you begin.
Tools and Supplies Needed....
Digital Multi Meter
Screwdriver (both Phillips and Flathead)
Ratchet Set
Drill
Wire Strippers
Wire Cutters/Crimpers
Heat Shrink Tubing
Solder & Soldering Iron
Ring Terminals & Tapping Screws
an11198 says: Oct 11, 2010. 5:37 AM
This is not a complete guide you didnt say anything about programming the remotes.??????
CarAlarmInstaller (author) in reply to an11198Oct 11, 2010. 2:35 PM
Programming the remotes is a very important process. USUALLY, the transmitters that are included with the alarm or remote start come pre-programmed. This means that they are ready to use out of the box. If they are not working, or need additional features added on, check the instructions that came with your car alarm. Programming remotes and the system vary greatly depending on manufacturer.
gotanks55 says: Oct 5, 2010. 11:10 AM
A good place to go for vehicle specific wiring diagrams is:
http://www.the12volt.com/
CarAlarmInstaller (author) in reply to gotanks55Oct 5, 2010. 7:51 PM
Absolutely! There are a few (free) places to find wiring diagrams online.
Including...
www.the12volt.com http://techservices.codesystems.com
http://www.commandocaralarms.com/wiringsearch.asp
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
JJEXP says: Sep 29, 2010. 4:27 PM
Might wanna add a little more detail, such as which wires not to touch under any circumstances. Hooking your volt meter up to the airbag wires (usually a twisted yellow pair which may or may not be sheathed in yellow tape) will blow the bags.
CarAlarmInstaller (author) in reply to JJEXPSep 29, 2010. 5:17 PM
Good suggestion...LOOK OUT for neon yellow tubing and/or yellow plugs. These are airbag wires, and you want NOTHING to do with them. Do not cut, unplug, or even look at them in the wrong way, as you do not want to accidentally deploy the airbags or trigger a service light.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
