loading
Step 5: Additional Tips
Converting a bathtub with a conventional window above it to a shower is dicey business, but the result is striking. Order a premade glass block window to fit your existing opening . Look under "Glass Block" in the Yellow Pages or online to find a supplier.
The key to a weatherproof, attractive glass block window both inside and out is to encase it in a custom-built wooden frame (Fig. A) The inside dimensions of the frame should be 1/2 in. taller and wider than the panel itself. That will give you room to adjust and shim the panel exactly and then inject expanding foam between the frame and the panel to lock it into the opening.
To begin, rip the top and side jambs to the thickness of the wall framing plus the exterior wall sheathing. The cement board will lap over the jambs. The windowsill should also be flush with the interior framing, but hang over the outside sheathing about 1-1/2 in. and have a 5-degree slope toward the outside to help shed water. To keep water from running behind the siding as it drips off the edge, cut a shallow groove (or saw kerf) in the bottom lip. Also, remember to flash behind the trim to keep the window watertight. Trim the window exterior to match the house, using caulk to seal between the trim and siding.
It's important to set the panel so it protrudes 1/4 in. past the finished tile surface. That way, a bead of caulk can seal the joint between the tile and block to keep water out of the wall cavity.
Tip:
Prime and paint the window jambs and sill before setting the glass block panel to save time-consuming painting details.
<p>This looks exactly how I will do the glass block window. I have done many carpentry projects after owning 15 property's. Thanks for your insight. I rate you A+ on this one.</p>
<p><br>you really need to check out this website.It is owned by the Dc Glass Repair who repairedd my Glass windows and it was so professional and clean.</p>
These are great instructions! I'm actually down in Vancouver right now working on a project. And I'm curious if you can install <a href="http://www.retroteckwindow.ca/retroteck-garden-vinyl-windows-vancouver-bc.htm" rel="nofollow">vinyl windows</a> the same way? Thanks!
About This Instructable
140,568views
137favorites
Bio: The Family Handyman is the DIYers best friend, offering a variety of print and digital resources for do-it-yourself homeowners. Our forte is accurate and complete ... More »
More by The Family Handyman:How to Use a Circuit Tester How To Clean Surfaces with TSP Tips
Add instructable to:
