3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Install an SNES cable onto a Multi-Console Cthulhu
Step 2Prepare the cable
Prepare the cable
This is a quick step, but very recommended to help make things go smoother. Tin your wires.
The easiest way I've found to accomplish this is to twist the copper wires together so you have no stragglers, then apply a little flux onto the exposed copper at the end of each wire. Melt a little solder on the end of your iron, and touch it to your wire. With the flux, the wire will drink up the solder, leaving a much easier to use and solder single piece to solder to the board, instead of multiple thin copper threads. The insulation on the wire will melt and retract a little bit; that will actually help make things easier when we solder.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:Toodles
