Step 3Prepare the wires
The easiest way I've found to accomplish this is to twist the copper wires together so you have no stragglers, then apply a little flux onto the exposed copper at the end of each wire. Melt a little solder on the end of your iron, and touch it to your wire. With the flux, the wire will drink up the solder, leaving a much easier to use and solder single piece to solder to the board, instead of multiple thin copper threads. The insulation on the wire will melt and retract a little bit; that will actually help make things easier when we solder.
Add Comment
