3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Isolate Splenda
Millions of people enjoy the fake sweetener in the little yellow package every day.
What they may not know is that the sweetening agent is only a minor component of what's in the packet. Would you like to get your hands on some pure, uncut sucralose? I know that I would.
Now, before you ask, you don't need fancy equipment or laboratory conditions to do this. If, however, you are like me - a grad student with some time to kill on the weekend - it sure doesn't hurt.
Step 1Educate!
Educate!
The active ingredient in Splenda, sucralose, is closely related to sucrose. In a five-step synthesis, three positions on the sugar are chlorinated, which renders it both indigestible and intensely sweet.
Like, 600 times sweeter than sugar.
So, if you got a sugar-sized packet of pure sucralose, your iced tea would taste like rock candy. So, Splenda actually contains mostly flavorless maltodextrin.
But how do we separate the sucralose from the maltodextrin?
Well, the chlorine atoms make sucralose much more hydrophobic (oil-liking) than an ordinary sugar like maltodextrin. So, by using a nonpolar solvent like acetone or isopropanol the sucralose can be dissolved and the maltodextrin filtered off.
For you organic chemistry fans out there, I've included the synthesis below.
127 comments
1-40 of 127next »
May 21, 2012. 5:29 AMALogan97 says:
As an alternate method (because this utterly refuses to work for me), could one use steam distillation? It apparently works for essential oil production, but would the sucralose be too heavy for the steam to carry? Or would the distillate still contain maltodextrin? I doubt that the steam distillation process would work for this, but I'm unsure, so I shall ask your opinions on it.
May 19, 2012. 11:24 AMALogan97 says:
If we use isopropanol, could we burn it off to speed up the evaporation process, or would this negatively affect the resulting sucralose?
Oct 16, 2011. 8:13 PMaakemp123 says:
If something is hydrophobic, that doesn't necessarily mean it likes oil, it means the substance doesn't like water. Acetone is a polar substance and wouldn't work in this experiment the same way isopropanol would. Good idea for an experiment though!
Sep 25, 2010. 9:17 AMrhangatoby says:
wait, if we shouldnt eat it if we used acetone, then why use acetone?
Jan 20, 2009. 4:41 PMsijmad says:
Is acetone is a "non polar" solvent? That is strange!!
Apr 18, 2009. 8:08 AMDeusXMachina says:
Sure you can! Ether comes in the aerosol engine starter fluid cans. And while you can't find benzene, you can use toluene or xylene, which are effectively the same in terms of hydrophobic properties.
Sep 23, 2010. 3:00 PMArano says:
you should not use benzene, as it causes cancer. toluene is does not (or at least there is no proof it does).
Sep 24, 2010. 9:10 PMArano says:
boilingpoint does not matter very much... its more about vapor pressure... and for your acethone its about a quarter atm at 20°C so all your acethone will vaporise very quick, as long as the acethone-vapor has no partial pressure of a quarter atm.
Jun 6, 2010. 7:58 AMArcticLiz says:
Hey! uhm.. I gotta question.. you still remember how much acethone you used?? Thanks! :D
Jun 6, 2010. 8:19 AMArcticLiz says:
oh.. I guess it will be useful.. thanks! :D
Jun 7, 2010. 9:01 AMArcticLiz says:
isolate the sucralose from Splenda (:
Jun 5, 2010. 4:32 PMArcticLiz says:
Hey! Thanks so much! Believe it or not I NEEDED some sort of isolation like this one for my chem class.. :D thanks sooo much!
Aug 18, 2009. 6:35 PMREA says:
what could the sucralose be used for once isolated?
Aug 18, 2009. 9:09 PMREA says:
perhaps its flamable? or explosive?or can react with stable molecules to make them radioactive?
Dec 12, 2008. 10:41 PMPie Ninja says:
Instead of Everclear would it be possible to use pure ethanol?
Mar 15, 2009. 5:40 PMdelphinkid says:
Everclear is essentially just ethanol in itself, so pure ethanol would work.
Mar 15, 2009. 10:44 PMPie Ninja says:
sweeeeet. (quite literally, actually :P)
Dec 28, 2008. 8:48 AMmontdor1 says:
Kitchen chemistry heaven. My question, and I mean this deeply and only in the spirit of information, is if there are any psychoactive properties to pure sucralose. And what are some uses for it? Is it a precursor to anything worthwhile, whatever that means?
Mar 15, 2009. 5:34 PMdelphinkid says:
No, sucralose is basically ordinary household sugar but with a few substituted chlorine atoms. If you could convert it back to sucrose or another sugar I suppose you could use it to make ethanol, but that would be a really inefficient way of doing it.
Jan 25, 2009. 12:24 PMKoolraap says:
What is everclear composed of ? i live in Holland and I'm pretty sure they don't have that brand over here :}
Dec 5, 2008. 2:52 PMmarine12320 says:
isopropanol is just isopropyl alchohol right? also, if i have like 90% Isopropyl alchohol, is it safe to taste a tiny bit of the sucralose?
Nov 25, 2008. 4:58 PMdniloc2cv says:
Not completely sure but USA plant is about 50 miles from me an I think one of the primary ingredients is Clorine...some such HazMat.
Nov 2, 2008. 4:36 PMwhorger says:
There is an acetone that is supposed to be as free of contaminants as possible. It's called "optics grade" acetone, and is used in the final cleaning process for the highest quality optical mirrors.
Still, having any thing in my mouth that once came in contact with acetone makes me shiver!
Give me sodium hydroxide (lye) anytime: re: ludafisk.
Oct 28, 2008. 9:20 AMlobo_pal says:
I like your rhyming steps, it makes science seem cool. Yes I do realize how geeky that sounded.
Oct 29, 2008. 5:34 AMlobo_pal says:
Is it save to eat, or will the sweetness make your toungh explode or something?
Oct 23, 2008. 11:28 AMAZsid says:
So, if you use Everclear and don't evaporate it off you would be left with a super sweetened mixer?
Oct 21, 2008. 12:10 PMFather Christmas says:
hmm. i might suggest this to my Chem teacher this year. I took the same class last year, but i needed another credit so it took it anyway. this could prove very entertaining...
Oct 16, 2008. 10:20 PMHarryone says:
You might try the local medium-box drug store for 70% ethyl alcohol. It has a trace of acetone (for the taste), but it's clean enough, and the acetone leaves soon enough. Getcher Splenda by the pound cheaply at WalMart or the moral equivalent (made in China, so you know it's... interesting.)
Oct 16, 2008. 11:55 PMrfmonaco says:
Why not just buy pure liquid sucralose from http://www.sweetzfree.com/ ?
1-40 of 127next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:Mongpoovian
