3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How To Isolate Splenda
Step 5Evaporate! Isolate!
Evaporate! Isolate!
Pour the filtered solvent/splenda mixture into a wide container and place in a well-ventilated area for a few days. The solvent will evaporate, leaving behind a thin film of pure sucralose. This stuff is so sweet, even sniffing it deeply will make your mouth water.
If you have access to lab equipment (or perhaps the MOST AWESOME KITCHEN EVER), you can cheat and strip the solvent off using a rotary evaporator, like I did.
I'm sure the question you're asking yourself is - can I taste it? If you used everclear, oh yes. It will be quite an experience. If you used isopropanol, it might be clean enough to sample - a little won't kill you. If you used acetone, I wouldn't recommend eating it.
Enjoy!
12 comments
Sep 25, 2010. 9:17 AMrhangatoby says:
wait, if we shouldnt eat it if we used acetone, then why use acetone?
Jan 20, 2009. 4:41 PMsijmad says:
Is acetone is a "non polar" solvent? That is strange!!
Apr 18, 2009. 8:08 AMDeusXMachina says:
Sure you can! Ether comes in the aerosol engine starter fluid cans. And while you can't find benzene, you can use toluene or xylene, which are effectively the same in terms of hydrophobic properties.
Sep 23, 2010. 3:00 PMArano says:
you should not use benzene, as it causes cancer. toluene is does not (or at least there is no proof it does).
Sep 24, 2010. 9:10 PMArano says:
boilingpoint does not matter very much... its more about vapor pressure... and for your acethone its about a quarter atm at 20°C so all your acethone will vaporise very quick, as long as the acethone-vapor has no partial pressure of a quarter atm.
Dec 12, 2008. 10:41 PMPie Ninja says:
Instead of Everclear would it be possible to use pure ethanol?
Mar 15, 2009. 5:40 PMdelphinkid says:
Everclear is essentially just ethanol in itself, so pure ethanol would work.
Mar 15, 2009. 10:44 PMPie Ninja says:
sweeeeet. (quite literally, actually :P)
Dec 28, 2008. 8:48 AMmontdor1 says:
Kitchen chemistry heaven. My question, and I mean this deeply and only in the spirit of information, is if there are any psychoactive properties to pure sucralose. And what are some uses for it? Is it a precursor to anything worthwhile, whatever that means?
Mar 15, 2009. 5:34 PMdelphinkid says:
No, sucralose is basically ordinary household sugar but with a few substituted chlorine atoms. If you could convert it back to sucrose or another sugar I suppose you could use it to make ethanol, but that would be a really inefficient way of doing it.
Oct 18, 2008. 1:28 PMdie_dunkelheit says:
Are you concerned about any impurity left behind by the acetone?
Oct 16, 2008. 12:24 PMragemaxis says:
if you did this in a quantified way i.e. with like 30lbs of raw incredient, such that you got more than a few grams of raw product - any number of different one or two-solvent crystallizations would work really well. take two co-miscible solvents that the substance is soluble in - particularily if they have a dramatically different solubility at varied temps. Dissolve substance in solvent A at high temp such that you have a little solid left at the bottom, add a drop of HOT solvent A to make it totally dissolved, drop in a speck of substance (if possible), a couple drops of miscible solvent (if desired) then cover with saran wrap and have cool as slowly as possible. If all goes well you will end up with big nasty evil looking crystals which you can then extract, filter under vacuum, dry out completely and use for your bidding. May not work with this though...
Oct 16, 2008. 3:06 PMragemaxis says:
you can go to bulk barn and buy it by the kg. there is always a solution, just ask your favorite hillbilly buddy, he can tell you how to turn anything into anything if you can handle a little you don't want to know left in it.
Oct 15, 2008. 7:47 PMjeff-o says:
I've always wondered what that gadget does. Now I know! Can I get one at Home Outfitters? j/k ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:Mongpoovian
