All you need to learn is some yarn and a pair of needles. In this Instructable I've used medium weight yarn and somewhat large needles, so the interlocking loops would be clearer. Most knitting is done somewhat tighter than this.
Remove these ads by
Signing UpStep 1A little bit of theory
The first pic shows the knit side, and the second pic shows the purl side. A purl stitch (it's spelled with a u but pronounced just like pearl) is exactly the same as a knit stitch except it's worked from the opposite side. The smoother side that looks like interlocking V's is facing you when you are knitting, and the bumpy side that looks like interlocking U's is facing you when you purl.
To start knitting, you'll need to "cast on", or fill up a knitting needle with starter loops. Then you'll knit some number of rows until the piece is the size you want. Then you'll "cast off", or close out all the loops so the knitting doesn't come unraveled again.
There are also varieties of ways to hold the needles and yarn. In this Instructable I'm using and discussing the Continental method, which basically just means the free yarn end is held in the left hand (pic 3). This end can also be held in the right hand, which is more common in the USA but to my mind a bit less efficient.
Great 'ible!
Canadian in mm's measurment...
Conversion?
Thanks...
Now I can knit again!!
Lillith
thanks for this :) :) i'll be adding you to my favorites!
i've made a green pot holder so far :]
what am I supposed to do with the remaining yarn ar the end and beginning ?? i did a scarf but it has yarn hanging out of it ... =( i hope i made myself clear with my problem... greetings from mexico =)
