Introduction: How to Make a "Secret Container" Out of a LIGHTER
Wanna learn How To Make a Secret Container Out Of a Lighter?
Watch the video or follow that Instructable
Disposing of about 1x2" of free space, you can use it to hide keys, joints, folded bills, etc.
It looks and works EXACTLY as an empty lighter, but if you LIFT the button (instead of push it), it will open the container revealing the content.
Learn now how to make it
Step 1: You'll Need...
- an empty Lighter
- the inner part of a Pen
- a saw
- a piece of sandpaper
- a piece of tape
- a clamp
- a cutter or a knife
- a saw
- a piece of tape
- a clamp
Step 2: Cut Off the White Cap
start cutting at 0.3" from the bottom of the lighter using the cutter or the knife in order to make a "path" for the saw, then use it to completely remove the white cap.
But carefully! You need it in a good state.
Step 3: Disassemble the Lighter
disassemble the lighter, remove ANY part you can remove, without losing anything.
You can use a screwdriver or just your finger.
Step 4: Expand the Free Space
When you have just the plastic body of the lighter, carefully start to expand the free space inside (using the cutter, scissors, a screwdriver, etc), cutting away and removing any useless part.
Step 5: Fit the White Cap
then, you need to clean the cap out of the plastic. Use the sandpaper to blunt the cap and the inner side of the lighter untill the cap fits very well.
Step 6: Re-assemble the Lighter
re-assemble the top of the lighter
Step 7: Insert the Pen
take the inner part of the pen and fold it (a bit longer of the lighter's lenght),
hold it with a piece of tape,
cut away 0.1" from the tip of the pen..
then insert it inside the lighter.
that represent the opening mechanism of the secret container.
Step 8: Tap the Lighter With the White Cap
tap the lighter with the white cap ...and Enjoy :-)
Thank You for Your Attention.
