-A CRT TV (color may work, but I'm not sure)
-Some wire
-A soldering gun
-Rubber gripped pliers (for safety)
-A screw driver
Remove these ads by
Signing UpStep 1Identify Wires
Inside wrapped around the CRT are two coils of wire, one controls the vertical deflection of electrons, the other controls the horizontal deflection.
Find where these coils of wire attach to the circuit board, and desolder one coil.
Place the cover back on the TV(for safety) and plug in and turn on the TV.
If you see a horizontal line, you desoldered the vertical deflection coil.
If you see a vertical line, you desoldered the horizontal deflection coil.
In addition, the high inductance of the coils may affect the output from the amp. Maybe a voltage follower of sorts would help, but I'm not really sure.
But on mine anything over about 1 volt goes above the screen, so I'm not sure if it would be much help (I don't know much about amps).
Hope this helps.
So it's definitely possible, it's just a matter of how....
Awesome idea by the way.
But I want to make a multi-mode oscilloscope out of my old TV, so I can use it as a usual oscilloscope and as an X-Y oscilloscope.
How do i do that?
This is because the Horizontal coil is part of the circuit of the high-voltage power supply. Some TVs will work with the Horizontal coil cut. Some will not. If your TV wont work, try connecting a different coil to the wires to keep the mainboard happy. An easy win is to use the coil from another TV or monitor and zip-tie it off to the side.
If you get it working, you now have a vertical line which repeats 60 times per second. You can loosen the metal clamp on the coils and rotate the assembly 90 degrees (turn it to the right, viewed from the back). Now you have a Horizontal line. You can feed signals into the old Horizontal coil, but they have to be amplified first - powerful enough to drive a speaker.
You can use an amplifier like a guitar amp. If you only need to boost a headphone-like signal, you can use the amp built into the TV set. Disconnect the built-in speaker and connect the Horizontal coil instead. Find the wires to the volume knob - one of them is "from" the TV tuner. Unhook that wire and connect it (and ground) to a connector on the outside of the TV. Note: sometimes "ground" is HOT and can shock the hell out of you. Check first. If it is, use a 1:1 transformer from Radio Shack between the knob and the connector.
