Step 4Connecting the USB wires to the fan's battery terminals.
iImage Information
This was done through trial and error. I found that while the fan would run both if the red were attached to the positive and black negative or red to negative and black to positive but the second way produced sparks at the negative-to-motor connection so I obviously chose the former hook-up. Wrap the indicated wire around the indicated battery terminal folding the wire over so it stays temporarily. Once this is done, plug the USB wire into your computer (NOTE: Do this instructable at your own risk, I will not take the blame if harm comes to you computer/yourself/etc but nothing bad happened to me/my computer when I connected the fan to the computer) and turn the fan on. If it works, on to the next step, if not, maybe the wires are not connected properly or maybe they are loose, play around with it,m it should work fairly easily (and as long as the fan does not require 3 x 1.5V batteries or more for operation (IE no more than 5 V) ).
Thank You!
CYa! :)
